Please help
Old Nov 19, 2002 | 10:14 PM
Diddy's Avatar
Please help
I was installing aftermarket fogs in my 2001 GXE. I had both fog lights run off of the drivers side side lamps. When I tested the lamps everything seemed to work fine. After I was done I decided to test it on the road, and as I was backing out the driveway, the fogs, side lamps, tail lights, parking lamps, and guage lights all went out. The funny thing is that the blinkers still work if I use the left and right turn switch, but they just don't come on with the head lights. I tried to put everything back the way it was, but that still didn't work. I'm thinking some fuse or relay thing went bad, but I can't find any fuses that are bad, and I'm just confused at this point. Plus I misplaced my Fuse remover , which is really ****ing me off right now. I thinking about going to a Nissan dealer for them to look at it, but that could mean dough which I don't want to spend. Can anyone help? Pleaseeeeeeeeeeeeeeeeeeee.
Old Nov 19, 2002 | 10:24 PM
chinaonnitrous1's Avatar
Re: Please help
I would definatly Re-check all fuses under the hood and under the dash. Otherwise..not sure howd you would check relays
Old Nov 19, 2002 | 10:45 PM
Chunger's Avatar
My other car is a Hybrid
2 possibilities:
1) you have a short circuit (loose wire got pinched,etc)
or
2) you sourced directly off the parking lights without using a relay and popped the factory fuse?
try the left column bat-7.5A tail light fuse
Old Nov 19, 2002 | 11:03 PM
Originally posted by Chunger
2 possibilities:
or
Wow...great info.and damn postin that pic was FAST!
Old Nov 19, 2002 | 11:06 PM
Chunger's Avatar
This is an old pic and I just 'reposted' it for someone earlier today... AGAIN.
Old Nov 19, 2002 | 11:07 PM
