Attn: x-drilled/slotted rotors owner, directions?
Old Nov 21, 2002 | 08:32 PM
ßaller's Avatar
I got the completed 4 set from raceconcepts.net, and believed I may have put the rotors on the wrong side after doing some research here.
On my driver side both the rotors face this direction in my cheesy drawing, plz tell me if this is right or not, thanks!
- ßaller
Old Nov 21, 2002 | 08:39 PM
Cumalot's Avatar
I heard some people say it doesn't matter which direction. I don't know about that. Anyway, I have the Stillen rotors and mine are in the opposite direction to yours.
Old Nov 21, 2002 | 08:43 PM
mtrai760's Avatar
'Trynna' is not a word
I have seen them in both directions, I don't think it matters... I have mine in the same direction...
Old Nov 21, 2002 | 10:10 PM
ßaller's Avatar
Okay here is a better picture of what it looks like on the driverside. Remember, these are from raceconcepts.net. Front rotors are Brembo fully x-drilled/slotted, rears are EMC fully x-drilled/slotted.
What is your config like, please edit my pic and show me yours and if it is the proper way, or like Mtrai who said its okay.
Another stupid question, if its labeled LH I assume it means Left Hand side, so would that be Driver or Passenger side? Don't worry, I do know the difference in front or rear rotors, just not the sides.
Thanks,
ßaller, need info asap since I will be at mechanic tomorrow to adjust the wheel nut, so he can swap for me, thanks!
Old Nov 22, 2002 | 06:10 AM
njmaxseltd's Avatar
Left is the driver side. I believe you have them on backwards. Even my x-drilled which were labeled L & R face forward, not backwards like yours do. The swipe should be from top to bottom.
Old Nov 22, 2002 | 06:11 AM
JAIMECBR900's Avatar
Mine are in the same position/direction as yours.
Old Nov 22, 2002 | 10:58 AM
95Max's Avatar
I had the same concern when I got rotors for my Z. I called Brembo and was told that the swip should be top to bottom.
Old Nov 22, 2002 | 11:00 AM
deezo's Avatar
Thanks,
Mine are on the opposite way.
Old Nov 22, 2002 | 01:03 PM
araffio's Avatar
So are mine
Old Nov 22, 2002 | 01:17 PM
nismo2020's Avatar
Needs non-Maxima Friends
baller mine are on the same way yours are. and thats how they were labeled.
just did them last night.
Old Nov 22, 2002 | 01:29 PM
99maxi's Avatar
i do not believe it matters... but i have mine on the opposite way because the box labeled the like that.. it really depends on the direction of the vents in the rotors..
Old Nov 23, 2002 | 01:05 AM
Chunger's Avatar
My other car is a Hybrid
As everybody else stated... It doesn't matter...
It only matter if the vanes are directional (our stocks are not) in which case it would matter.
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 26, 2015 12:01 PM
