wheel stuck...any suggestions?
Old Nov 27, 2002 | 07:31 AM
MikeyMax's Avatar
My right front wheel is stuck on my car.
the lug nuts came off fine, but then the wheel itself won't budge.
I took it to NTB (national tire battery), and they said, "we're just gonna hit with the hammer...nothing else we can do."
Any suggestions? this has never happened before.
Old Nov 27, 2002 | 07:32 AM
UMD_MaxSE's Avatar
Got Bent?
Knock it off with a rubber mallet....
Old Nov 27, 2002 | 07:48 AM
MaxSE03's Avatar
Set on the ground in front of tire. Kick the sides of the tire, alternating left and right. It will come off!
Old Nov 27, 2002 | 08:27 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
kick it from the inside
Old Nov 27, 2002 | 08:47 AM
1MAX2NV's Avatar
Kick the tire while you are sitting down on the ground. Make sure your car is on good jack stands. The wheels is stuck on the hub part due to rust.
Old Nov 27, 2002 | 10:10 AM
guido_sst's Avatar
I keep a heavy nylon coated hammer around for just this sort of thing, one or two good whacks is usually all that's required and it won't destroy the finish of the wheel.
Old Nov 27, 2002 | 10:51 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
ya it happened to me a couple times with the stock rims because they are HUB centric and get rusted on, just kick it hard a few times on each side of the tire making sure the jack stands are holding the car up good and it will pop off.
Old Nov 28, 2002 | 07:03 AM
MikeyMax's Avatar
thanks for the replies...but
the wheel is still stuck.
Can't figure out how it's stuck on there so well.
I bought a BIG rubber mallot and hit the sh*t out of it from the inside, but still... no luck.
Old Nov 28, 2002 | 07:29 AM
BlackCat's Avatar
RIP '98 Maxima SE
How about spraying some WE-40 on it, let it soak for a few minutes and try pulling it off again?
Old Nov 28, 2002 | 01:14 PM
MikeyMax's Avatar
Liquid wrench
yeah, I thought that would losen it up...but didn't.
I tried spraying Liquid wrench where the wheel meets the hub. No luck.
What else can I do?
Old Nov 28, 2002 | 03:02 PM
Re: Liquid wrench
What else can I do?
kick is really hard on each side.
Old Nov 28, 2002 | 03:05 PM
Sin's Avatar
Sin
How 'bout some preventative maintenance guys?
I ALWAYS clean my hubs and hats of all rust at every tire rotation, and summer/winter switch over. I simply use a brass wire brush attachment on my 18V cordless drill. Or, simply go buy a brass brush for like $2, and do it by hand. I have NEVER EVER had a problem with hubs getting stuck on, and I live in Toronto, in the heart of the salt belt.
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
240tomax
Sep 13, 2015 03:28 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
