Timing Chain Cover Removal
Old Dec 3, 2002 | 04:10 PM
JDM4LIFE's Avatar
anyone done this? i've got about everything off of my engine but this. the manual says it should come off by tapping it with a hammer and a block of wood, no luck. also tried a putty knife, to no avail, it still sits attached, and yes, i'm sure EVERY bolt is taken off. any help?? I'd just like to get this back together almost to have my car running already
Old Dec 3, 2002 | 04:42 PM
MaxSE98's Avatar
Re: Timing Chain Cover Removal
i dont know what seals the two together but try heating it up with a hair dryer. if its as cold where u are as it is here a little heat couldnt hurt - pete
Old Dec 3, 2002 | 05:52 PM
JDM4LIFE's Avatar
i'll give it a try, it's just not wanting to budge in the slightest though....
Old Dec 3, 2002 | 09:23 PM
ny96max's Avatar
wheres Daniel B MArtin when you need him
Ant
Old Dec 3, 2002 | 09:35 PM
JDM4LIFE's Avatar
Ant
exactly, maybe he'll catch this post in the morning. i got the top part of the seal to break loose, but there's no way i can find any place to get it apart down below
Old Dec 4, 2002 | 12:31 AM
96_vqmax's Avatar
Are you talking about the outside cover?there are two 12mm?? bolts on the upper oil pan need to remove before you can take the timing change cover out.You will also need to remove one the long bolt that holding the front engine mount.In order for you to remove this bolt you will have to lift the motor or drop the motor(or you could drill a hole through the frame like i did to mine easier)a lots of work,and it is easier to pry the timing chain cover out on the bottom,i hope this will help and good luck.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxinout93
Oct 27, 2015 01:29 PM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
