i need help guys....my electrical system is going insane :(
Old Dec 6, 2002 | 08:30 PM
Soon2BMaxed's Avatar
well my car just decided to go crazy on me tonight after work. i got home and i hit the lock button on my remote and the lights flashed like normal.
i went back outside an hour later to get something out and when i hit the lock button the lights flashed once and the doors locked but all my dash lights were on for some reason (brake,check engine, seatbelt, door ajar,etc.)
so i hit my remote to unlock it...nothing. i had to manually unlock the door with my key and i put the key in the ignition and the car starts but flickers the lights and resets my stereo settings (wtf?) BUT when i go to turn off the car again all the lights in the dash flicker really fast and make this "click click click" noise then stay on.
could someone help me with this? do i have a bad relay or something?
Trevor
Old Dec 6, 2002 | 09:43 PM
HitManSE's Avatar
man that kinda tough, its like askin some1 to operate blindfolded. need to play with the wires with a test light be4 anything can be said 4 sure. unless some1 else has a good suggestion? i dont know what to say. sorry i wasnt much help, goodluck.
Old Dec 6, 2002 | 09:53 PM
BBaker025's Avatar
I dont really know much about this electrical system stuff. But since about a week ago my electrical system was messin up also. Sometimes my car wouldnt start, no lights would come on, keyless entry wouldnt work, and other times it would work great. Like Wednesday my car wouldnt start so I got a ride to school, and after school I posted my problem here and some one said to clean battery connections and terminals, which I had never done. So I went out and cleaned them and it started great. I havent had any problems since, so you might want to clean the connections and see if that helps any. Just my .02
Old Dec 6, 2002 | 10:03 PM
i just cleaned them last week when i added a better battery ground this f-ing sucks.... i guess i'll just check all my fuses and relays tomorrow, i dont know what else to do
Trevor
anyone else?
Old Dec 6, 2002 | 10:46 PM
Dave B's Avatar
Not DAVEB the parts guy
Sure sounds like something is wrong with your "hyper" grounds. Automotive electrical systems are really tempermental and I wonder if it has something to do with the gauge wire you're running.
Dave
Old Dec 7, 2002 | 09:40 AM
Dave
Hmmmmm...im gonna put back my factory ground cable and see if it changes anything.
Old Dec 7, 2002 | 02:28 PM
guido_sst's Avatar
It's probably not an issue with the wire gauge, but I was thinking it could be related as well.
Trevor - Let me know if you can't figure out what's going on and I'll bring over the digital VOM or the scope and we can do some checking.
Old Dec 7, 2002 | 03:03 PM
well i put in my factory battery ground and now everrything is fine
Old Dec 7, 2002 | 05:25 PM
guido_sst's Avatar
I think we need to design a better setup.
Some ideas:
Solder all the connections
Make sure we get connectors the correct size for the wire
Make sure all the connections have some heatshrink tubing between them and the outside
Clean all the factory grounds well
etc
I think we were just rushing through it too much due to the cold, maybe we can get a spot in someones garage and really make a system that works.
Old Dec 7, 2002 | 10:01 PM
nadir_s's Avatar
vicodin ... gift of life
hmmm...
perhaps the connection w/ ure ground wires were loose or something or somehow touched a positive charge connection somewhere.
Old Dec 7, 2002 | 10:55 PM
HitManSE's Avatar
thats wierd, really wierd. sucks u had to go threw that but atleast u got an easy solution out of it, must have obviously been defective.
Old Dec 7, 2002 | 10:58 PM
nadir_s's Avatar
yeah seriously, you got outta it EASY. trust me, some of the posts i've read about electrical problems SUCK NUTS.
My advice is to **** the ground wire upgrade, it's a useless mod that you can live w/o; don't **** w/ your electrical system anymore, your max doesn't like it.
Old Dec 8, 2002 | 01:42 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
