a question for those that did the hyperground mod
Old Dec 7, 2002 | 02:23 PM
Soon2BMaxed's Avatar
how did u do your battery ground? i noticed that the factory cable was grounded once by the battery tray then the end of it was grounded by the engine. well, i replaced the cable with 2 guage RF cable but i didn't "double-ground" it.
the last 2 days i have been having crazy electrical problems. my dash would go completely dead while driving then come back on when i tapped my brakes. well i put back my old factory wiring and now everythin is fine.
how did you guys do it?
Trevor
Old Dec 7, 2002 | 02:24 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: a question for those that did the hyperground mod
Trevor
Look for a post from jaimecbr900 his car would not start after trying that mod. There might be some info there
Old Dec 7, 2002 | 03:04 PM
Re: Re: a question for those that did the hyperground mod
thanks
Old Dec 7, 2002 | 03:07 PM
mtrai760's Avatar
'Trynna' is not a word
I did mine, but I just added to the existing wires. I left the stock battery wire in place, and just supplemented it. It worked fine and I never had any problems. check out the NW forum under ground wires for pics.
Old Dec 7, 2002 | 03:46 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Here's what I did:
I left the existing ground wires intact, include the very important negative battery post wire-to-body-to-engine ground intact.
Starting from the passenger side of the engine compartment:
I installed a wire from the alternator bracket ground point to the engine bracket ground point.
I installed a wire from the engine bracket ground point to the negative battery post.
I installed a wire from each of the two intake manifold grounds (2 wires from the fuel injector harness loom grounding on the intake manifold) to the factory battery-to-body ground point (next to the battery tray like you mentioned).
Everything is fine and my motor revs smoother
Old Dec 7, 2002 | 04:48 PM
ThurzNite's Avatar
My bro installed on top of stock wiring. No issues, just a meaner sounding exhaust and probably 5-10hp butt dyno boost.
Jae
Old Dec 7, 2002 | 06:18 PM
Nismo's Avatar
on my homemade hyperground wires I made, I added a 4ga from the battery post to one of the screws that hold the relay box thats right next to the battery.
Mar 12, 2020 12:06 AM
ballerchris510
Sep 23, 2015 08:46 PM
pears
Sep 18, 2015 05:25 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
Johnny9595
Sep 3, 2015 05:18 AM
