those who did the home mad engine mounts....
Old Dec 15, 2002 | 01:48 PM
Soon2BMaxed's Avatar
i got a set of used motor mounts to do the urethane thing but i have a few questions.... when you fill them do you gut out all the factory rubber thats in there or do you just fill the gaps in the stock rubber with the urethane? my rear mount is the one that is busted but the rear one in the used set i just got is busted too.
also do you know the part number for the mix? thanks!
Trevor
Old Dec 15, 2002 | 02:33 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
no need to gut them. just fill them as is..
http://www.mcmaster-carr.com
Old Dec 15, 2002 | 02:43 PM
damn. thats what i just realized. you see, i thought we had to gut them then fill them completely not just the gaps. i wonder if i can do this when the mount is already busted. CRAAAAP. do you know what the actual name of the stuff is? i looked on that site but all i could ifnd were sheets of urethane, not the mix. thanks!
Trevor
Old Dec 15, 2002 | 02:46 PM
ericdwong's Avatar
I did not try to "repair" a mount, so I suggest getting a new one. I think the rear one is the one that breaks for most people. Theres a writeup on the 4th gen FAQs that tell you how to do it and what material.
Old Dec 15, 2002 | 03:36 PM
BSwithTF's Avatar
I think it could be done.
It'd take a little more work but if you gutted all the rubber out and made sure to keep the metal bushing thing exactly in the middle, no reason why that wouldn't work. That's what the PR urethane mounts look like. Good luck getting that rubber out of there, though. That **** is hard! If you can do that with the rear one, then you could fill the gaps on the front one and you'd be good to go.
Old Dec 15, 2002 | 05:53 PM
97maximase5spd's Avatar
Old Dec 15, 2002 | 11:01 PM
Re: home mad engine mounts
Originally posted by 97maximase5spd
Old Dec 16, 2002 | 05:55 AM
Dreizehn's Avatar
Home "mad" engine mounts....
Old Dec 16, 2002 | 12:05 PM
Lordrandall's Avatar
3M Window Weld....
http://www.nx2k.com/nx2000/hd_mounts.htm
Old Dec 16, 2002 | 12:48 PM
Re: Re: home mad engine mounts
DJLAX152
May 4, 2021 11:46 AM
seesole
Sep 14, 2015 12:38 PM
16_SR
Sep 9, 2015 07:14 PM
