Build an all motor beast or turbocharge... opinions
Old Dec 15, 2002 | 06:42 PM
Nealoc187's Avatar
SLOW
So, I've been doing some thinking lately about what to do with my car. I'd almost convinced myself to stay all motor and build an all motor beast. Then there are all these sick turbo kits coming out for the max, and putting down retarded amounts of power for like $4000, out the door.
Currently I'm putting 180ish to the ground, on a 140K mile motor. Never tested compression or leakdown, but I assume for now that they're ok, as I'm turning good times and putting down good power.
So, the options are:
1) Budget all motor: get ECU, Cams, valvesprings and the rest of the bolt-ons. Looking at about $2500 in mods plus $250 for clutch, probably see 220 to the ground.
2) All-out all motor: everything listed above + 3.5L shortblock from a 2002+ Max, Alt, G35, 350Z. With my heads the resulting compression would be 11.6:1. Probabaly looking at 280-300 to the ground. Cost would probably be in the $4500 range all told. Also, the 3.5L block swap hasn't been done so there might (and probably would be) unforseen expenses and downtime. Clutch also needed ($250), and tranny bellhousing mating is unknown at this point (not sure if my trans will bolt up.)
3) Turbo kit: t3/t04e or t04e kit, nice FMIC, all hardware, guages, FULL 3" mandrel bent exhaust from turbo back included, tial wastegate, MBC, timer, FPR, fuel pump, etc. $3999 out the door, INSTALLATION INCLUDED IN THE PRICE if I make the 5-6 hour drive to Kentucky. On 4.5psi the kit puts down 280ish, 11psi 370ish, 14psi 430ish, the block is good to 18psi I'm told before internals go kaboom. Reliability is up in the air, the kits are too new for anyone to know how they will hold up. I'd also need a clutch, another $250.
So, opinions?
Old Dec 15, 2002 | 07:22 PM
Larrio's Avatar
The Definitive AE Master
hey, if you got the money.. just go all out with the craziest stuff money can buy.
my vote is for crazy 3.5L tubro'ed
Old Dec 15, 2002 | 07:26 PM
Vyrus's Avatar
Boost that bish! You'll have more power than you know what to do with.
-Cyrus
Old Dec 15, 2002 | 07:38 PM
KLoWnPR109's Avatar
I would go with the turbo setup. It'll be more flexible, plus you can get a turbo where it'll spool later so you wont have to worry about gaining traction as much compared to now if that makes any sense.
Old Dec 15, 2002 | 07:55 PM
dmontzsta's Avatar
Ford Only.
I highly recommend the turbo set up. A all motor set up is nice, but you dont have the options like you do with boost. You can set up your car to run on low boost for daily driving and then pump it up for the track or the weekends. I personally think once you go boost, the increases in HP are unlimited, that is when the stuff like exhaust and intake really count. Go boost, you cant beat it and especially the sound.
Old Dec 15, 2002 | 08:10 PM
Conrad283's Avatar
I need a truck
turbo
Old Dec 15, 2002 | 08:14 PM
nismo2020's Avatar
Needs non-Maxima Friends
be real orginial---> 3.5 all motor gets my vote
Old Dec 15, 2002 | 08:20 PM
SonicDust187's Avatar
How about building the engine to handle all that boost. How about 30psi of boost sound?
Old Dec 15, 2002 | 09:12 PM
A-Ron Max's Avatar
I'd say to go w/the budget all motor setup. With 140k miles, I would be very concerned about doing something thats going to put a lot of extra stess on your engine like the turbo kit. On the other hand if you just have money burning a hole in your pocket, go for the more expensive all motor setup, not only would you see some nice gains in performance, but it would show the rest of us what we could all possibly get out of these new upgrades, either way good luck!
Old Dec 15, 2002 | 09:26 PM
I30tMikeD's Avatar
All motor.
Old Dec 15, 2002 | 09:32 PM
MAXIN's Avatar
All motor, you were the first to hit 13's NA, so you should be the first high HP all motor max.
Just keep tabs with MardiGras on his 3.5L swap.
Old Dec 15, 2002 | 09:33 PM
nadir_s's Avatar
vicodin ... gift of life
if u go the all motor route, how would the gas consumption be like? just curious...
Old Dec 15, 2002 | 09:39 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
built motor and boost IMO, more versatility and depending on the motors stength will always make more power than an N/A build!
N/A build will only go but so far....after its done thats is.
Old Dec 15, 2002 | 11:00 PM
Nismo87SE's Avatar
I say go with a VQ35DE. While the motor is out you can hardcore on pistons, cams and whatever. The boost route that is scary. I wouldn't buy a turbo that would put out more power than my fuel injectors could handle IMHO. You should run 370cc injectors as a bare minimum and then you still can't adjust the ignition timing. But I'm sure a greddy Emanage would help solve those issues. But ideally your looking at $1000 after the install of the kit to get it running properly.
AT www.car-part.com you can get a VQ35DE for $1000-2500, figure $300-2000 depending on the motor work you get done. AFter your finished you could part out or sell your old motor and recoup some of the difference. Besides an All motor VQ35DE would own, especially if its tuned .
Old Dec 15, 2002 | 11:33 PM
chinaonnitrous1's Avatar
sorry to butt in.....but vq35deT with a 6 speed...would rule if swapped in 100%
Old Dec 15, 2002 | 11:47 PM
dmontzsta's Avatar
Ford Only.
Old Dec 16, 2002 | 06:37 AM
carnal_c30's Avatar
Former Sponsor
I would consider all motor- win some money too
I duno, seriously I think an all motor car is better at more track events than a boosted car, and its a different route- I would encourage you to keep on the same track and do something different!!
Old Dec 16, 2002 | 06:58 AM
hlh0501's Avatar
you know what gets my vote...
just a little correction... as far as stock internals holding 18psi? for how long are you wanting this engine to last, a couple minutes - months? you need to be extremely careful when boosting 10+, and above 12 you had better be willing/ready to get a new motor unless you have built internals
to make the decision easier, I would say ride in a turbo'd maxima haha, it is a lot different then just the videos I can post up, to actually feel the push back in your seat
Old Dec 16, 2002 | 11:00 AM
Nealoc187's Avatar
SLOW
I was told by someone that Turbo95Max finally got the stock motor to pop at 18psi. That's far more than I would ever expect to run, as I don't plan on building the motor (at least thats the plan for right now). If I were to go turbo I'd set it at 9 or 10 psi and leave it there. Maybe 12 for runs at the track.
Old Dec 16, 2002 | 11:16 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
b00st
Old Dec 16, 2002 | 11:27 AM
Jeff92se's Avatar
I'm needing a caw
You are forgetting one important element. All motor build ups are fine IF you have the correct ecu program to go with it. Since no one really makes an ecu programs for 4-gens or for your application, you will have to go stand-alone. That will kick your budget up another $1,500 for purchase + another $xxx for dyno time tuning.
Old Dec 16, 2002 | 11:43 AM
4DRSpeed's Avatar
Project Ruby......
I would really like to see #2. An all-out all motor 3.5 block dropped into your 4th gen. That would be some crazy ****!
Old Dec 16, 2002 | 12:28 PM
Lordrandall's Avatar
Boost
Old Dec 16, 2002 | 12:29 PM
Black VQ's Avatar
I love speculative threads like this.hehe It would be really cool if you stayed NA. I can understand you wanting to go turbo though.
If you can pick up a 3.5L block for cheap, I'd say to turbo that. There's the fitment issues to worry about, but hopefully it won't be as a big a deal as getting stand-alone engine management.
[stupid idea]
I dunno if it would work, but maybe you could get the 3.5L block, swap out the crank from the 3L, and bring the displacement down to around 3.2L(?).
You could possibly use the 3L heads, too. I have a feeling that the CVTC isn't helping peak torque figures. A 3.5L 5th gen should be making much more than only 246lb-ft.
If this all works, you could keep the bigger bore of the 3.5L block and still rev like the VQ30DEs were meant to. It'd be a really nice NA motor. It could be a good turbo motor too, if you lowered the compression.[/stupid idea]
Lastly, you could just turbo your VQ, but get everything checked out first to make sure it's in good condition. You could use either the VQ30DET's 9:1 pistons or get a set of custom pistons in the compression you want.
Whatever you do, I'm sure the "Darth Vader Max" will go like stink when you're finished!
Old Dec 16, 2002 | 12:30 PM
Sprint's Avatar
[shameless plug]
www.turbomaxima.com
[/shameless plug]
I know you are a member already
Old Dec 16, 2002 | 12:48 PM
speedtrip's Avatar
Re: Build an all motor beast or turbocharge... opinions
I've been debating over a 3.5L all motor vs turbocharger myself. My maxima has 111,000 miles on it and is my only source of transportation. OK I have a motorcycle but I'll be d!mned if I'm going to ride it in 30 degree weather. I'm leaning more towards a turbo at this point.
IMO cams and ecu are not worth the cost and the amount of work that is necessary. A built 3.5L sounds good but will require more planning, downtime, and money than a turbo. Another reason I like a turbo is that you can take it off and sell it if need be. Should the need arise, selling a built motor is alot harder because of the size and weight involved.
My biggest concern with either a built motor or turbocharger is what if I'm involved in an accident and my max gets totalled. Let's face it, with a high-mileage vehicle, an insurance company much rather write you a check and sell your car for parts to recoup some of the loss, than repair it. Again I think a turbocharger would be much easier to deal with in a situation like this.
Old Dec 16, 2002 | 03:17 PM
surfermax92's Avatar
I'd go with the full blown NA route. While boost is great, it seems that there can be way more problems, too much money spent on tuning, and more stress on the engine. Also, there are so few fast NA maximas
Old Dec 16, 2002 | 03:33 PM
DTR Maxima's Avatar
i would say boost for sure. it gives u more options, and its cheaper. with a built 3.5 there are complications u could run into and your car could be in the shop for a long time, or maybe it just wont work out right, u have seen the numbers people are putting down with a turbo setup. and like said before, if your in a bad accident (total worthy) u can just pull the turbo out in a couple hours or so, try pulling out and transporting a built motor, and then u have 5grand down the drain and i dont think insurance will cover that.
either way, good luck deciding! (this is one of those choices that keeps you up at night) when i was deciding between boost or 5speed swap it took me about 2 months to finally be sure of myself on getting the 5speed swap
Old Dec 16, 2002 | 05:20 PM
NYCe MaXiMa's Avatar
if you're trying to make it fast
just go all out and boost it..
Old Dec 16, 2002 | 07:58 PM
MAXIN's Avatar
this should have been a poll...
Old Dec 16, 2002 | 09:39 PM
BEJAY1's Avatar
Conecarver
3.5 motor, spray, AWD.
Old Dec 17, 2002 | 05:52 AM
deezo's Avatar
HuH????
Old Dec 17, 2002 | 08:53 AM
VQdriver's Avatar
i was talking to the mechanic doing my S13. he said that a 2000 maxima would bolt on to the 4th gen head just fine. not sure about 2k2 motors though. turbo is the easy way to get it done that's for sure. you won't be able to boost very much with such high compression obviously. so you'll go fast, but you won't be able to push the limits of boost until you swap out the internals. that means more $$.
Old Dec 17, 2002 | 03:50 PM
outkastist's Avatar
i like the all motor idea...i wanna see someone take the initiative! i would try it but im a broke a@@!!!!!!
Old Dec 17, 2002 | 03:53 PM
BBaker025's Avatar
BOOST!!! Then I can ride in ur car if you come to KY!
Old Dec 17, 2002 | 04:08 PM
Street Reeper's Avatar
Handsome
Congrats again on the great all motor times.
In an ideal world I would get the 3.5 transplant. But how long are you planning on keeping your car?
The turbo would be relativly easy to take out and keep for the next car.
Swapping the motors back would probably be harder, and finding the next car for that motor would be harder than finding one to turbo.
The all motor budgeting would be my first choice, then the turbo, then the 3.5 swap. If practicality was out the window, my choices would be in reverse order.
Good luck, no matter which way you go you'll have a great setup.
Has the fact that your car is FWD, played any role on your choices?
Old Dec 17, 2002 | 04:27 PM
SuDZ's Avatar
It would be cool to go all out and see waht an all motor VQ is capable of.
SuDZ
Old Dec 17, 2002 | 07:08 PM
96BLUMAX's Avatar
I think since you have claimed your fame as a fast all motor, why not just stick with that and go for the 3.5 swap. Also cause i want to see what the complications are cause i would like to do it when my engine gets a little more worn out. Would you do the work yourself?
REDinLV
Aug 15, 2024 12:30 AM
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
Apr 16, 2020 05:15 AM
