UDP worth it?
Old Sep 10, 2000 | 04:23 PM
TexMaximum's Avatar
Should I get a Under Drive Pulley, and will it help regain any of the lost HP verses the stick shift maxima? Is it worth the money and possible install hassle? Thank you.
Old Sep 10, 2000 | 04:58 PM
wicked1044's Avatar
go get it..you will get about 5-8 hp. with it. its not too much $$$
Old Sep 10, 2000 | 05:20 PM
Nismo87SE's Avatar
its better than a catback....
It makes about the same power as a catback does except you don't lose any lowend torque. Its a nice mod check the classifieds for UDP's so you can get it cheap.
Old Sep 10, 2000 | 08:14 PM
TexMaximum's Avatar
Thanks. I got the G-reddy slightly used. Shipped and installed for about $400 total. Mostly for looks and sound but it did have a noticable gain. So the catback wasn't just for HP.
I heard the UDP is hard to install and could cause the car to leak oil. True? What is the HP advatage of a stick shift max? Just for example; would a UDP auto max all stock, stand a chance with a 5 speed all stock of the same year?
Old Sep 10, 2000 | 08:34 PM
Nismo87SE's Avatar
nope the only way an auto would be a 5spd is with a higher stall torque convertor and Don's VB mod. Other than that it will take more mods than that. The UDP on my car is easy to install I can do it like 1-2 hours. If you have a gear puller ($15 from autozone) its easy to remove. Once you break the crankshaft nut you use the gear puller and the pulley comes right off.
Forge277
Jun 13, 2016 09:26 PM
lrb6805
Sep 30, 2015 08:12 AM
homewrecker
Sep 24, 2015 07:01 PM
Dasmith
Sep 23, 2015 08:28 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
