question about fog lights
Old Jan 7, 2003 | 04:46 PM
JMAXIMA's Avatar
i'm planning to remove my old fog lights and put in some aftermarket ones shortly. but i don't know what kind to get... either projection or reflective (standard type)... i don't know what would put out the best beam pattern. i'm not looking to spend a lot... maybe $50-60. i'm just looking to add some better visibility... as everyone with stock fogs on a 4th gen knows, they suck. so if anyone could suggest one over the other, i would greatly appreciate it. thanks
-jon
Old Jan 7, 2003 | 11:04 PM
moggy291's Avatar
After changing your foglights you should try the Type-R or the super yellow bulbs. These bulbs shine very bright unlike those cheap brands that actually decreases your visibility. YOu can check them out at Hyper-Shift.com
Old Jan 9, 2003 | 06:40 AM
JMAXIMA's Avatar
anyone else?
Old Jan 9, 2003 | 09:58 AM
sinewave's Avatar
Are you looking for better visibility during fog conditions or under normal nightime conditions? If it is the latter, you ought to know that there is a big difference in beam pattern between a fog light and a driving light.
Old Jan 9, 2003 | 05:34 PM
JMAXIMA's Avatar
i'm just going for better overall night time visibility. i don't live in an area with alot of fog, so i guess my terminology wasn't correct. so if anyone can suggest a relitively inexpensive ($50-75) driving light to replace the stock fog lamps... and if not... maybe just what might be better for visibility... projection or reflective (for a lack of a better description).
Old Jan 10, 2003 | 03:22 PM
sinewave's Avatar
The 95-96 fog lights are a pretty odd shape and size; I don't know of any lights that are made to replace them. How are you going to cover the holes in your bumper?
I've heard of some people going with overwattage bulbs, I wouldn't recommend it; it could do severe damage to your electrical system. You would get more light, but in the same fog light pattern since the light patttern is controlled by the reflector and the lens.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
