Compressor maps
Old Jan 19, 2003 | 03:19 PM
CandiMan's Avatar
Say Candyman 5 times
Compressor maps
Anyone knows how to read these maps? Just to throw a couple at you
http://imagem.webphotos.iwon.com/100...M0.1882898.jpg
http://imagem.webphotos.iwon.com/100...PM0.414085.jpg
http://imagem.webphotos.iwon.com/100...M0.4460195.jpg
To me these formulas and number looks like French, but I know they show a valuable info about each particular map
Old Jan 19, 2003 | 05:54 PM
Nealoc187's Avatar
SLOW
I know how to read them but when I clicked the links to your maps I got THIS:
Old Jan 19, 2003 | 06:00 PM
Matt93SE's Avatar
STFU n00b!
go to ray hall turbocharging website... there's a TON of info there that will help.
also try a google search on it..
BTW... can anyone find a compressor map for a Garrett T-300?
Old Jan 19, 2003 | 08:25 PM
CandiMan's Avatar
Originally posted by Nealoc187I know how to read them
If you can host them any maps will do. My three had no particular purpose, I just grab them out there.
Originally posted by Matt93SEgo to ray hall turbocharging website... there's a TON of info there that will help.
I found some good information with googles, but I'm still lost with the different calculations and numbers
I'm just looking for a simple ABC and 123 explanation, don't really have to get too technical
Old Jan 19, 2003 | 09:01 PM
Matt93SE's Avatar
STFU n00b!
http://www.turbofast.com.au/turbomap.html
Old Jan 20, 2003 | 03:45 AM
BigDogJonx's Avatar
Definetely good info Matt.
Here are a few questions maybe you or someone can answer.
1. What is the best efficiency % I should be looking at when getting a turbo? Or is that all dependant on what I want to do? I hear if it around 75% then you are over working the turbo.... Im lose on this slightly.
2. What if I plot a point that doesnt even hit the map, like lower than the map, does that mean Im in turbo lag and inefficient?
Basically where I fail to get these maps is that the turbo gives me different psi depending on what I send from the boost controller. So I would have to plot a rack of points and see what is best for me. Also when Im looking at a turbo lets say a t3/t04e, which one do I look at when looking at a map, the t3 or the t04e?
Sorry for the dumbazz questions.
Old Jan 20, 2003 | 07:34 AM
Matt93SE's Avatar
STFU n00b!
there will be a map for that particular turbo somewhere..
if the points are below the chart, then you just won't make boost, period. it would be wise to choose a smaller turbo then- as long as you don't go over the top of the map on the high end of your RPM range.
05' MaximaMan
Oct 8, 2017 06:36 PM
viperboy
Sep 27, 2015 07:05 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
