Brake Consultation Needed / low pedal,good pads
Old 01-28-2003, 05:54 AM
patrick leber's Avatar
I have a 91 Maxima SE with 75,000 miles on it, bought new. My brake pedal is low and spongy. I replaced the rear pads, bled the rear lines, calipers are all good, working and not leaking. All rotors good and within acceptable thinckness range. Front pads only 1/3 worn.
I was thinking its the master cylinder (original), but the brakes wont pump up and are a bit spongy. Could it be the extreme cold combined with water logged old fluid?
Any thoughts fellas?
patrick leber is offline
Old 01-28-2003, 06:15 AM
njmaxseltd's Avatar
Low spongy pedal could be caused by a few things.
Air in the brake lines.
Caliper hung up on the guide pins, it isn't squeezing the pads correctly, but rather pushing one pad into the rotor and pushing the rotor into the other pad. This causes excessive caliper piston movement which in turn causes excessive pedal movement.
Defective master cylinder.
njmaxseltd is offline
Old 01-28-2003, 08:30 AM
optimus1's Avatar
spongy brakes ...
also, Brake line expansion; ageing rubber hoses sounds like ...
optimus1 is offline
Old 01-28-2003, 08:37 AM
1MAX2NV's Avatar
Bleed the front too. A bad master cylinder, you won't get any pressure at all. You pretty much have to bottom out the brake peddle to stop the car.
1MAX2NV is offline
smplyamzng
12-13-2015 01:19 PM
MAXSE5SPD
08-23-2015 12:06 PM
TonyJr
08-20-2015 12:14 AM
egali045
08-16-2015 01:19 PM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: Brake Consultation Needed / low pedal,good pads
