Maxima Reliability
Old Feb 10, 2003 | 05:14 PM
jack63ss's Avatar
Maxima Reliability
I just purchased a 2000 GXE 5spd with 29,500 miles. The car is mint, the service record shows no warranty work, just oil changes. My question is can I count on this car getting to 100,000 miles (probably in ~4 years) without having any problems or should I spend the money on an extended warranty plan ? Given you can't get anything fixed on a car for less then a couple of hundred bucks, spending $1,000 for a warranty doesn't sound like a bad deal.
Opinions & Comments ?
Old Feb 10, 2003 | 05:15 PM
Sprint's Avatar
yes
Old Feb 10, 2003 | 07:56 PM
Eric L.'s Avatar
Originally posted by SprintMax
yes
hehe good answer
for whats its worth, i don't think you need the extended warranty
Old Feb 10, 2003 | 08:01 PM
Green 2kSE's Avatar
I would spend the $1000 on a set of good tires if the car is still on the stock (Im)potenzas.
Old Feb 10, 2003 | 09:32 PM
krbga's Avatar
coil packs.
Old Feb 10, 2003 | 10:49 PM
95emeraldgxe's Avatar
100K miles is an almost definite, as long as you dont crash - which hopefully wont happen
Old Feb 11, 2003 | 12:41 AM
dmontzsta's Avatar
Ford Only.
260,000 here
Old Feb 11, 2003 | 02:00 AM
geo1317's Avatar
yes
let see, new clutch(300) after having the can for 5k miles, new axle(85), new wheel bearing and hub(250) plus labor(550). I know the clutch isnt covered under warranty, but im just venting, i got the car last march with 42k and have driven about 10k.
so if you are buying a used car get the extended, who knows what the car has gone through(my records said the same only oil changes and nothing else).
Old Feb 11, 2003 | 03:56 AM
NickStam's Avatar
Re: Maxima Reliability
Originally posted by jack63ss
The car is mint,
just because they washed the car doesn't mean it is well under the hood.
Old Feb 11, 2003 | 07:54 AM
slavik'sMAX's Avatar
don't waste your money
don't buy the extended warranty, there are alot of repairs that could be done for a 1000 bucks, and you should see 120,000 - 150,000 without a major repair..........
Old Feb 12, 2003 | 09:50 PM
jemartin's Avatar
I have to disagree with not getting the warranty from experience. In one and a half years of use of my 2000 GXE, I've had it to the dealer about 8 times. The problems were as follows:
Window switch
Stop light Switch
ECU
Brakes Rotors
Ignition Coils(at $180 a pop)
Among other things, I believe my VI is malfunctioning. I have 46K on my car, luckly I have the extended warranty. It has provided me with a rental car on 3 different occasions and is worth the money. Do not get the car without it. It is a first year of a newer model and those tend to be more problemmatic. However, I can say that I love my Maxima and is a lot more reliable than my previous car(a 92 grand am). Unless its a 97-99 which is a more mature model get the extended warranty, it increases resale value and helps you out in the long run.
Old Feb 13, 2003 | 06:19 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
It sounds like the previous owner of your car may have beat on it. I picked up my 99 5spd with 43k (just off lease) and haven't had so much as a single problem with it. I have 67k on it now after a year. I passed on the extended warranty, but was always a bit leary about buying a used car. Hopefully it'll hold together.
Knock on wood
Old Feb 13, 2003 | 06:30 AM
maxfanfromohio's Avatar
Shiver me timbers.
I would say don't buy the warranty. However if you do, make sure it covers the little things not just the major repair items or it is definately not worth the money. Remember you can get a good look at a steak by sticking your head up a bull's a$$, but wouldn't you rather take the butcher's word on it? I have no idea how that ties in, I just wanted to say it.
Old Feb 13, 2003 | 11:57 AM
geo1317's Avatar
Knock on wood
yeah he or she did, cause i think it was a corporate car that they gave to someone to drive in.
Old Feb 13, 2003 | 02:50 PM
DTR Maxima's Avatar
YES!! get the warranty. maxima's are reliable cars but sh*t happens. i bought my 97' about 5 months ago and the extended warranty has already paid for its self and then some.
Goffery2uned
Aug 21, 2015 09:50 PM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
julian888
Aug 6, 2015 04:39 AM
