Heat Not Blowing Not Air. Whats the problem?help asap
Old Feb 12, 2003 | 06:22 PM
95MaximaSport's Avatar
I have a 95 Maxima the heat does not work what could be the problem? I changed the water pump and the Thermostat. The car doesn't overheat or nothin it runs good, but the heat just wont blow hot air why is that?
Thanks Alot
Old Feb 12, 2003 | 06:33 PM
kramerica72's Avatar
Re: Heat Not Blowing Not Air. Whats the problem?help asap
Thanks Alot
maybe the heater core is clogged...
Old Feb 12, 2003 | 06:34 PM
karguy's Avatar
Thanks Alot
A couple of things come to mind, 1. is the flow control valve moving when you go from hot to cold or cold to hot? 2.Are the air control doors working, if air isn't passed through heater radiator you get no heat either. I'll bet a cup of coffee on number 1 or its controls.
Old Feb 12, 2003 | 07:03 PM
Kashoggio's Avatar
sounds to me like you have air in the system flush
Old Feb 12, 2003 | 07:26 PM
Aphrodisiac's Avatar
are there any DIY things you can do?
SonicDust187's Avatar
My blows hot air but not that hot. In my friends altima its like 100 degrees on 3rd setting, with me my rth doesnt even come close. What can I do?
Old Feb 13, 2003 | 12:39 AM
Mine did too, I dont know what to do about it, before 32 (digital) was blistering hot, enough to cook an egg. now I only get !hot! air when I'm going on the highway with a warmed up car and using the dash vents only (can't use floor/combo/windsheild vents or else cold air would blow instead)
Right now I drive with the tips of my fingers (too cold to touch steering wheel)
Yes, my system is definatly FUBAR, I want to try to fix it myself this summer... that'd be intresting
Old Feb 13, 2003 | 03:54 AM
Frank Fontaine's Avatar
Thanks Alot
I saw 2 good ideas on this thread, which would not be Maxima specific, and those were the heater core and control valves. But here's another question (gasp)--do you have auto climate? That would complicate things. I have it, and from what I can observe, that controls the vents, the heater, and the fan. If you have that, it introduces an electronic element as well. Mine often switches fan speeds without me doing anything, while the da** thing is on MANUAL!! I've learned to live with it.
I would assume that whether you got auto climate or not the heater control valve would be the same. What commonly happens is that begins leaking (not Max specific) and the coolant doesn't make it to the core. But you will start seeing wet carpeting etc. Anti-freeze is a nasty material to deal with, so be wary of any leaks. good luck.
Old Feb 13, 2003 | 07:35 AM
Phoenix1911's Avatar
My money is on clogged heater core, unless its a late model max with the auto stuff in which case it may be sensor.... Our old van showed all those same symptoms, drove prefect, engine never overheated but no hot air would blow... I disected the old core and the tubes were all corroded and filled with gunk preventing hot coolant from flowing... If your core is clogged you may be in for a new radiator as well
Phoenix1911
Old Feb 13, 2003 | 07:51 AM
jkotel's Avatar
Wrong thread aye?
Old Feb 13, 2003 | 07:59 AM
Sin's Avatar
Sin
Yah man! I'm a little cracked out right now. Went to the Government Mule show last night. Partied a little too hard
captchaos
Mar 15, 2016 12:18 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
conansriver
Sep 11, 2015 10:26 AM
jwright36
Sep 8, 2015 11:45 AM
