will i mess my shocks up if...
Old Feb 19, 2003 | 10:12 AM
JMAXIMA's Avatar
i can't afford to buy a new suspension set right now, so i'm considering doing something i read on here. cutting out some rubber spacers and putting them around the shafts of the rear struts. but in doing so i will have to cut away the rubber protecting the shaft... so am i inviting something to get in there and damage the strut? and by the way, this is for track use only, but once the rubber guard is gone, i can't put it back on.
Old Feb 19, 2003 | 10:20 AM
Sprint's Avatar
is the extra .1 or .2 seconds really worth all that work?
i mean so you come off with a faster time.. then you will go..
so i run XX.X@XXXmph.. BUT i had to ....
to answer your question.. i don't know how it will affect the struts... talk to njmaxlimited.. he eats.. breathes.. sleeps and *****.. suspension
Old Feb 19, 2003 | 12:26 PM
JMAXIMA's Avatar
yeah, i do think a tenth or two is worth an hour / hour and a half of work. its not the work i mind... i actually enjoy working on my car when i can spare the time... kind of a release from work and classes. i just don't want to do anything to damage my car... that was the point of my question...
Old Feb 19, 2003 | 01:00 PM
njmaxseltd's Avatar
That will only help your launch slightly!
Not worth the trouble and if you do scratch the piston, your SOL.
Save some $$$ and put AGX shocks in the rear, then dial them up nice and stiff on track day.
I'm not so sure you'd really see a big change in your 1/4 times, but I'm no track guru either. There are probably a lot of other things you should be looking at to improve your 1/4 with our cars.
Old Feb 19, 2003 | 01:07 PM
Colonel's Avatar
Old Fuddy Duddy
...and *****.. suspension
I could not even imagine passing a coil, let alone a strut, shock or RSB!
Old Feb 19, 2003 | 07:13 PM
ereet's Avatar
Re: will i mess my shocks up if...
Jime has spacers he uses for the back springs and he has one of the best, if not THE best launch time for a maxima on the .org .. As far as I know, he didn't cut, or damage anything and I believe it only takes a small amount of time at the track.
Old Feb 19, 2003 | 07:22 PM
JMAXIMA's Avatar
Re: Re: will i mess my shocks up if...
thanks man... i believe that Jime was the guy i got the idea from anyhow. he's got the 97 auto with a wet kit right? anyway, thanks again.
Old Feb 19, 2003 | 10:15 PM
98maxsel's Avatar
talk to Jime
litch
123
Jan 4, 2024 07:01 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
homewrecker
Sep 24, 2015 07:01 PM
