make me feel better orgy...
Old 03-01-2003, 05:13 PM
Cumalittle
broke my 2 inner tails...cracked one of my outer tail...and successfully open up my other outer tail...i'm feeling a lil bit down rite now fellow orgy member...tell me ur experience while making ur red/clear tails...those of u who successfully done it the first time...don't post...cuz i hate u...
Old 03-01-2003, 05:18 PM
I need a truck
Conrad283's Avatar
Re: make me feel better orgy...
don't feel bad ... emax broke like 3 pairs of tails
Conrad283 is offline
Old 03-01-2003, 05:20 PM
Master Will
metallic97gxe's Avatar
try try again don't quit.....
but next time make sure it it heated up enough.....hot but not melting hot.....
metallic97gxe is offline
vicodin ... gift of life
nadir_s's Avatar
we all love u
nadir_s is offline
Old 03-01-2003, 05:31 PM
njmaxseltd's Avatar
Set your oven to 250 and bake those babys for 20-30 min. Go slow, take your time, pry evenly, use some cleaner wax to clean up the mess the glue makes on the lenses b4 your put them back together.
I've helped a few orgy members do red/clear tails. Most were sucessfull, except for one.... Bad thing is, the set that cracked wasn't my car.
njmaxseltd is offline
Old 03-01-2003, 05:40 PM
Sprint's Avatar
Sprint is offline
Old 03-01-2003, 05:42 PM
Cumalittle
i've thought bout baking them hoes but skeered the wifey mite ***** if something unfortunate should happen to her oven...
Old 03-01-2003, 06:55 PM
Cumalittle
hope that damn superglue hold...
Old 03-01-2003, 08:02 PM
Cumalittle
ok...superglue is not holding my broken pieces together...and when i go to put my lense back..it don't fit all the way in...wat is up w/ that???
Old 03-01-2003, 08:04 PM
Nathan's Avatar
Try heating up the factory glue so that the lense can go back into the housing. I've done 2 red/clear's and broke 2 lenses on my first try. When sealing them back up I used outdoor cocking which did the job at sealing them boyz up.
Nathan is offline
Old 03-01-2003, 08:05 PM
Chick specializing in rounding up 100+ Maximas
97MaxGurl's Avatar
oh my
just ask Doug .. he does it for a nominal fee though
AnGe
97MaxGurl is offline
Old 03-01-2003, 08:10 PM
Lime's Avatar
Sprint! hehehe.
Try a heat gun. It's better than an oven. Just don't set it too hot LOL.
Lime is offline
Old 03-01-2003, 08:21 PM
Permanent Maxima.org Resident
Confused's Avatar
stop feeling sorry for yourself and start planning the next one.
Confused is offline
Old 03-01-2003, 08:27 PM
Mike92GXE's Avatar
D_Warner did his, got it right, he might have some advice
Mike92GXE is offline
Old 03-01-2003, 08:38 PM
emax02's Avatar
Re: Re: make me feel better orgy...
Hehe, different circumstances though, mine used rubber cement rather then the stretchy glue stuff.
emax02 is offline
Old 03-01-2003, 08:54 PM
97MaxGurl's Avatar
Originally posted by Lime
Sprint! hehehe.
Doug ... dba (doing business as) Sprint
Old 03-01-2003, 09:09 PM
iansw's Avatar
Bought a set from an .org member knowing I'd rack at least 1.
Tried the heat gun first, then the oven.
The oven was 10000% better.
200 degrees, for 10 minutes, then try and pull apart with an old set of oven mits - if it doesn't come easy, 5 more minutes in the oven - repeat as necessary.
Makes the house stink for a little while because a little bit of the glue burns off, but no biggie.
iansw is offline
Old 03-01-2003, 09:58 PM
Cumalot's Avatar
Sorry to hear that bro.
So, I'm guessing you're posting with this handle from now on? Is the other still active?
Cumalot is offline
Old 03-01-2003, 10:16 PM
Cumalittle
new car new identity i guess...shh...
Old 03-02-2003, 04:08 AM
i SeE what you did therE
redmaxpa007's Avatar
i cracked one when i did mine..
redmaxpa007 is offline
Old 03-02-2003, 10:00 AM
Weasel's Avatar
It's like the Matrix...
OH NOS I FELL OFF TEH BUILDING ...er... CRACKED TEH LENSES!! WHAT DOES IT ALL MEAN?!!?!
It doesn't mean anything, everyone cracks them the first time.
Weasel is offline
Old 03-02-2003, 10:16 AM
Cumalittle
3 out of 4 is pretty bad don't u think???
Old 03-02-2003, 10:22 AM
I need a truck
Conrad283's Avatar
Re: Re: Re: make me feel better orgy...
i know, i was just makin him feel better
and bustin chops
Old 03-02-2003, 07:39 PM
¿Hablas Español?
joaquink's Avatar
I cracked one when I dropped the lens on the way back out the garage from the kitchen.
joaquink is offline
Old 03-02-2003, 07:42 PM
Cumalittle
talk bout cool feelings...now thas a cool feeling..thinking that u were better then most the first time...then u drop the lense...very cool feeling...
Old 03-02-2003, 09:16 PM
Shiver me timbers.
maxfanfromohio's Avatar
When I read the title of the thread I thought you were having a make me feel better orgy.
maxfanfromohio is offline
Old 03-02-2003, 10:24 PM
NYCe MaXiMa's Avatar
I've messed up quite a few myself.
My first attempt, like most, was unsuccessful. I used the oven but left it in there for too long and melted the lens.. but the damn thing did pull apart like butter.
I cracked a corner, and cracked them down the middle twice. Another time they were done well but someone in my family turned over the table i left them on and cracked those too
After different methods and attempts. I think I pretty much perfected doing red/clears now.. and have done approximately 20 sets for org members and people on the street.
I found the heat gun to be the easiest and safest way..
I use a propane torch though
Key is PATIENCE.
Do not, ever pull on the corners. Only in the middle, and pull evenly on all sides.. heat evenly on all sides as well.. keep going over and over... eventually they'll buldge.. then heat them more, they'll buldge more and finally let go..
If you are in the NY area i can help you out.
NYCe MaXiMa is offline
Old 03-03-2003, 04:04 PM
Cumalittle
well...from 100 ft out...they don't look too bad...no floresent cover for meeh...just pulled the amber and clear piece out...
Old 03-03-2003, 04:31 PM
djPlayboy's Avatar
i took apart my head lights, had slight problems getting the driver side back together, dont worry.... **** happens(especially when you dont want it to)
djPlayboy is offline
Old 03-03-2003, 05:22 PM
BioMaxDDS's Avatar
well is this makes you feel any better. I broke 2 studs while replacing rotors. $200 to fix at dealer
BioMaxDDS is offline
Old 03-03-2003, 05:42 PM
Cumalittle
2 stud?? $1 each at autozone...bang out the old..hammer in the new...
Old 03-03-2003, 06:24 PM
BioMaxDDS's Avatar
after breakin' 'em i was just feeling really frustrated. and there was a grindin' sound coming out from the wheel with broken studs (after installin' rotors). So i thought if they change studs they'll have to take everything apart than put 'em back in. well, after they fixed the studs, the grindin' sound was gone.
Old 03-03-2003, 06:33 PM
Old Timer
d_warner's Avatar
Oh well man. If you decide to buy some extra lenses, let me know. Bring em to the house and we can do em in my oven. The wife doesn't have to know about it! I've done the tails and the AE headlights now. Both came out pretty good. Let me know.
David
d_warner is offline
Old 03-06-2003, 10:55 PM
Dallas Nissan Enthusiast
darrick's Avatar
just my .02
i have found that if you pre-heat the oven to 200 then let the tailights bake for 12 min then get a buddy to use a heatgun pull slowly from center if they dont pull apart ez then heat em up more use light force and never pull from edges or stand on edges ,it will go very nicely.
Darrick-
DNE-
darrick is offline
Old 03-07-2003, 05:10 AM
Cumalittle
my tails don't look too bad from a distance...and it look pretty good if i may add...i like it w/o the inserts...
Old 03-07-2003, 02:13 PM
hacim105's Avatar
Everybody just gets impatient when doing their taillights. If you just take your time you won't break them.
hacim105 is offline
03-12-2020 12:06 AM
97_GXE
09-15-2015 06:47 AM
ballerchris510
09-11-2015 05:29 PM
AT978
09-06-2015 10:31 PM
Quick Reply: make me feel better orgy...
