MERCON V Spec
Old Mar 5, 2003 | 11:25 AM
jmichnya's Avatar
MERCON V Spec
Have any of you tried this fluid in your tranny? Still can't tell how this differs from DEX III, but I think it may be superior. (most formulations to meet spec are semi-synthetic, better low/high temp performance, better wear spec, etc). It was developed to eliminate lock-up shudder, which I have on my 4th gen. I understand we can use regular MERCON (same trans in Mercury Villager), but I don't think it's anything special. Also, what is special about Nissan matic fluid "D"? Who makes best fluid for reasonable cost?
Old Mar 5, 2003 | 01:35 PM
JustMaxin96's Avatar
Re: MERCON V Spec
IWANNABMW will be here in a min. he is an AMSOIL dealer, I just bought some tranny fluid from him very nice and knowledgeable guy.
Old Mar 5, 2003 | 02:10 PM
iwannabmw's Avatar
Re: Re: MERCON V Spec
Am I that predictable
You are correct in noting that the Mercon V spec was created to help eliminate shudder in Ford's transmissions. To the best of my knowledge, all the fluids that meet it are at least Group III fluids or better, there are no conventional ATF's that can do this.
There is nothing special about Nissan's D Matic ATF, it is a conventional fluid that has the frictional characteristics that meet the Dexron III requirements. Any fluid you can buy off the shelf that says it's Dexron III compatible can be used.
Personally, I wouldn't bother considering a Mercon V fluid. I would either choose a regular ATF or go with a full syn instead. In any case, if you're experiencing shudder in a 4th gen tranny there is a problem. Changing the fluid might be all you need to do (it's hard to say without knowing any history), but there might be a bigger issue at work as well.
Old Mar 5, 2003 | 02:20 PM
Re: Re: Re: MERCON V Spec
[QUOTE]Originally posted by iwannabmw
[B]
Yeah you are
I told you he knows his stuff!
James92SE
142
Jan 2, 2024 09:23 AM
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
