Dynoed my Maxima...Not Happy
Well here is my dyno sheet:
First Run: 181.8 HP and 195.6 Ft/lbs of torque
Second Run: 180.8 Hp and 194.5 Ft/lbs of torque
My car currently has 46K on it and is a 2000 Manual. I have a Cattman Y-pipe and JWT intake as my only engine mods. I am very disappointed in my car right now and something is clearly wrong with it once again.
I have two ideas on what could possibly be wrong.....
A. I have one of the older Cattman Y-pipes on (purchased in August 01') which could have a broken flex section.
B. I installed 1 step colder Copper NGK plugs....Yes these are the wrong plugs, but it shouldn't make much of a difference.
No, the colder plugs will make a significant difference...I lost ~5fwhp and ~10fwtq with them (dyno proven). Some say they lost even more. Nevertheless, the colder plugs are definitely affecting your numbers. How much? I dunno. There's only one way to find out. =)
Oh yeah, also fix your y-pipe if it's leaking.
BTW, why are you running colder plugs? Planning to go boost or nitrous? hehe
Originally posted by SprintMax
you can lose up to 30 fwhp on cold plugs
The reason I have these plugs in is because of a mistake. I forgot to write down the part number for the NGK plugs, so we called up Neal and he gave us the wrong number.
Originally posted by MAX2000JP
WOW...that's quite a bit of power loss....
yeah Sonic dyno'd 136 fwhpish at maxus with bolt on's and a 95 GLE on colder plugs
I think that the plugs arent that big of a problem IMO. From the dyno, it looks very similar to BriGuyMax's dyno with a broken flex. I am going to check it out ASAP.
Re: Dynoed my Maxima...Not Happy
Re: Re: Dynoed my Maxima...Not Happy
Originally posted by Frank Fontaine
Your post made me think of an article on the new Neon SRT-4 where it dynoed for more than Dodge reports. I can't believe a $19,000 car does 102 in the 1/4 mile. I admit it is a Neon, but wtf with those numbers! gonna get a lot of HS students toasting middle-aged men in their 2-seaters!
As for the original post, why do those numbers look that bad? Doesn't a 2000 have 222 hp stock? So you've got about an 18% parasitic loss, which may be just a tiny bit high for a manual tranny. As for your mods, I wouldn't really expect as much an improvement on a 2000 compared to a 95-99 with the same mods. Isn't the intake and the exhaust where most of the extra 32 horses 2000's have come from? I'd look at simple things such as the colder plugs, which I think are definitely worth a couple. Tire weight has a profound effect. You said you have stock 17" rims, but what is the weight of the actual rubber? If you have high performance tires, they weigh more than "standard" performance, and vary by manufacturer. Check your flex pipe for leaks, may be losing something there, but I doubt it would be noticeable. Are you getting any codes like the infamous 0304 (KS). Retarded timing would affect your numbers, and KS's are so common. I don't know where you live, but up north they use a lot of oxygenated fuel in the winter. This cuts emissions, but affects power.
With your mods on a 2000, I'd only expect a maximum of 4 hp from an intake and 8 hp from a y pipe to the wheels. That, with an 18% parasitic loss from the drivetrain, would give about 192 hp to the wheels. I really think that 4 and 8 hp for those mods is a generous guess for a 2000 with its intake and exhaust already. But I don't have a 2000, so you may want to check with others to see what you should realistically expect from them.
I really don't think anything is wrong with your car. May be some little things that affected your numbers slightly, but nothing to worry about. Personally, I'd be happy with you numbers (if they were on my '97)
Dave
Re: Re: Re: Dynoed my Maxima...Not Happy
Dave
Dave
4th Gen's dyno'ing 190 and more fwhp and upper 190's tq..
The car is making decent torque (but still maybe a little low), but the horsepower is WAY low which indicates it really falls apart more than normal at the top-end. As previously stated, plugs *CAN* make a big difference if they're one range to cold and have gone bad, and the classic y-pipe flex section failure could possibly cause it as well.
when a y pipe is blown.. its basically like open header.. you loose low end torque but your hp at high rpm increases drastically.. so its not a blown y pipe flex
But weren't some of the flex sections crimping out so that there was only a pee-hole path for exhaust through the rest of the exhaust system?
Yes, "blown" y-pipe (as in NO y-pipe) or completely blown out flex section would be the same thing as an open header, but I think you would definitely hear some changes in engine tone if that happened
Re: Re: Re: Re: Dynoed my Maxima...Not Happy
you can get those numbers easy on a 97 .. i think thats his main concern..
I'd check codes just to be safe; it's free, easy, and takes minimal time. Could reveal a bad KS, which will cut power and mileage, but not give a CEL or drivability problems (I've had 2 on 2 different Maxima's). I'd also get the proper heat range copper NGK's because they are cheap enough I could justify the cost of them for troubleshooting. Depending on mileage on car, possibly injector cleaner (mine likes Lucas Fuel Treatment, but it's more of a personal preference thing). And I'd check all other maintenance items like oil, filters, PCV.
Dave
my car pulls harder @ higher rpms... with blown y pipes.. and i am on the 3rd one
Re: Re: Re: Re: Re: Dynoed my Maxima...Not Happy
I know those numbers are easy to get on a '97, because the intake and exhaust on 95-99's are more restrictive.
Aren't 2000's intakes and exhausts the main reason they get 32 extra hp stock compared to a 95-99?
What I was trying to say is that with the 2000's better stock intake and exhaust, an I/Y wouldn't produce as big a difference than same I/Y on a 95-99. Also, 95-99 SE's come stock with 16", his has 17's. That surely cancels out some of the 32 extra horses from crank to the ground.
With his numbers, he's showing about an 18.5% loss from crank to wheels, assuming his car made 222 hp at the crank stock (remember that every car is different.
Some 2000's are more powerful than others, if only by a horse or two. It's a side effect of mass production). I would think that would be a decent number for parasitic loss if he was auto, but he's not.
and he has a 2k 5spd
Whatever the reason for his minimal loss, I'd guess it is something simple, such as his colder plugs, bad gas (oxygenated for cold weather emissions or water), tire weight, or even a bad KS. If his flex pipe was "crushed", meaning more restrictive, that could be it, too.
his car is pulling all the way to redline so his VIS is working perfectly.
But if it is just a leak, I doubt it would have too much effect.
Dave
Dave
Pee-hole sized flex section from my car: http://boostedmaximas.com/y2kevse/im..._flex_section/
Originally posted by GotVtec
IT MUST BE A DRAG TO DRIVE A CAR WITH UNDER 200 WHP AND WEIGHT OVER 3000 POUNDS!
SAD TRULLY SAD
SAD TRULLY SAD
Why not just spend a few dollars on the cheapie copper plugs in the correct heat range and test again? It MIGHT take 1/2 hour.
If different range plugs DIDN'T make a difference, when why are you running them(ie.. for nitrous/boost)?
No wonder you get killed by that 350z so badly on the highway. Should not be as bad as you were mentioning a while back.
Looks like plugs or the VI is not kicking in.
IT MUST BE A DRAG TO DRIVE A CAR WITH UNDER 200 WHP AND WEIGHT OVER 3000 POUNDS! SAD TRULLY SAD
Don't you think if we wanted an Integra, we could have bought one?
Therefore we choose a maxima because it's just as fast as your teg, has much more room and if we want rice, we cook it.
my dad owns a maxima 2000 model 5pd and it feels like driving a tow truck haha!!ofcourse his is 100% stock its basically a family sedan
I have more fun in my integra for sure but different stroke for different folks
ironic though when my teg (gsr) was stock with basic i/h/e I would hang with a 2k maxima with ypipe mod, full 2.5 exhaust and an intake
Im not saying maximas are slow in any way.... I just don't think the 30k+ price tag is a good car to start with specially if your're a student
The IP Address is: 64.231.221.55. The host name is: HSE-Montreal-ppp125586.qc.sympatico.ca. Please click here to return to the thread.
"hang"? whatever.
Alot can happen with an incompetent driver behind the wheel... of ANY car.
I paid 9K for my max.
i/h/e on a honda maybe adds 15hp the most
I would think on a maxima having more displacemnt a ypipe, exhaust/intake would net him more power I guess not??
