Dynoed my Maxima...Not Happy
Re: Re: Re: UPDATE
Originally posted by Dave B
I think JP's problem is that he's too caught up in the "numbers". Maybe it's the machines they're using in Chicago because I think Neal's GXE dynos just around average, yet he's the quickest NA 4th gen out there. Like I said, it's just a tool.
Dave
Dave
A used C5 or new WRX is starting to sound awefully good right now
Re: Re: Re: Re: UPDATE
Originally posted by MAX2000JP
I suspected the dyno at first, but Brian's Z pulled 244 RWHP just minutes later. Thats on the higher side of 350Z dynoes I have seen. This leads me to the conclusion that the dyno is accurate. I am just clueless to whats wrong here. I changed my plugs, cleaned the injectors, cleaned the MAF sensor, and checked my flex. I cant think of anything else besides the coil packs being defective, but my car makes good torque.
Matt
My best run of the day is below:
60': 2.27
330': 6.315
1/8: 9.638@73.2
1000: 12.508
1/4: 14.915@94.72
The weather was in the high 30's IIRC and I removed the jack and spare. I had a 1/4 tank of 93 octane fuel.
I had ran a best of 15.0@95 previously at RT66 IN 90 degree weather and very high humidity last summer.
The car is clearly not making power up top....Take a look at my dyno. My VI is clearly working, thats the funny thing. I heard it switch over on the dyno and my friend watched it actuate.
FYI....My brother in his auto 99' ran nearly the exact time I did and I30MikeD ran a 14.6 that same day.
60': 2.27
330': 6.315
1/8: 9.638@73.2
1000: 12.508
1/4: 14.915@94.72
What I'm seeing is a car that's lacking lowend power. Your 6.315 isn't terribly quick even though you came off the line with a decent 2.27 60 foot. Your 1/8 is okay, but your trap is a little low (73mph). But looking at your final 1/4 mph of almost 95mph, your car is gaining almost 22mph. That's STRONG. What do I think the culprit is? Those damn stock 17s. Those 55lb tanks kill your initial acceleration. Next time try and run on some 4th gen 16s or try and find a 40lb 17" combo. My ASA LS5 17" combo with 235/45s weighs in at 41lbs or 1lb lighter than my stock 15" combo. The LS5s were $1100 from the Tirerack. Cheap and light 17" combos are out there. A guy in the KC Maxima GAINED .3-.4 and LOST 3mph going with those heavy 2K+ rims.
Dave
Dave
Dave
Re: Re: Re: Re: Re: UPDATE
Originally posted by blubyu2k2
not to go too OT but does brain have his dyno sheet scanned. I have a buddy that doesn't believe a 350z can take a cls 6 spd with all the bolt ons. His best run is 14.4 @ 100.8 and I know the 350z has a higher mph stock if driven properly. Thanks and sorry to jump OT.
Matt
Matt
Dave
Dave
FYI...The time I post at RT66 was with nothing removed and a full tank of gas.
Re: Re: Re: Re: Re: Re: UPDATE
Yea he has it scanned. Its on my350Z.com...Search under BriGuyMax and "dyno" and it should pop up. If you cant find it, I will look when I get done with work.
TallTom
57
Oct 14, 2025 05:16 PM
JoshG
Sep 16, 2015 08:56 PM
