Engine rattle-update/fix
Old Mar 7, 2003 | 09:19 PM
Bgohan's Avatar
I've posted on this problem before, but since forum can't be searched....
I had the dreaded engine rattle at 2500-2800 RPM under light loads, like up a slight hill and light-medium throttle or on cruise control. (97 SE, 63K miles, auto).
After trying other things, reading the service manual, and beating my head against the wall, I finally put some good fuel system/injection cleaner in my tank ( glove box manual say's not to).
Problem went away. I've put on 1500 miles since, and the rattle has never returned. It was not a ping. And more than a knock. It sounded more like metal rattling at about same RPM of engine. Noise was not present when not under a load, or full throttle.
Must have been running too lean under certain conditions due to a plugged injector, maybe EGR, or something else related to a dirty fuel delivery system. Anway, you the in-fuel tank cleaner or having injectors professionally cleaned before going to a dealer to get ripped.
Some have had their timing chain replaced only to have the same noise be there $1200 later. (Or coil packs, plugs, EGR, knock sensor).
Old Mar 7, 2003 | 11:56 PM
Nismo's Avatar
Re: Engine rattle-update/fix
Sounds good to hear, I been noticing a weird rattle also for the past year or so. I always thought it was somethign loose under the hood that vibrated but Ill give the cleaner a chance since I cant figure exactly what this noise is.
BTW what brand cleaner did you use? I used that chevron techron stuff in the blue bottle like 6 months ago but obviously the noise is still here
Old Mar 8, 2003 | 01:45 AM
Dev's Avatar
Dev
Re: Re: Engine rattle-update/fix
yeah i'd also like to know...
i would like to clean the injectors before i encounter any problems
Old Mar 8, 2003 | 06:55 AM
GimmeTorq's Avatar
Which brand??
BG 44K and Amsoil PI are quite recommended.
Old Mar 9, 2003 | 02:16 AM
Bgohan's Avatar
I used, and only because I had it in laying around my garage for my truck, Slick-50 Fuel system cleaner. No, it does not have PTFE in it. It is made by Quaker State Oil co. Ask a good mechanic what he recommends. Sometimes an auto parts store will have a guy that knows his stuff too. The cheap stuff ($1-5 bottle) probably won't work.
let me know if the cleaning helps.
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
