when replacing front struts
Old Mar 14, 2003 | 03:46 AM
Frank Fontaine's Avatar
has anybody noticed front suspension noises going away? I'm curious because I saw a response that the front strut bearing could be the cause of popping noises. Sounds like struts need to be removed anyway to get at the bearings. I know that 4th gen boots are torn in the early 30's-40's, so that's dirt that it gets prematurely exposed to.
Old Mar 14, 2003 | 04:22 AM
njmaxseltd's Avatar
The dust boots only protect the strut's piston from contamination. The bearing, which sits up in a tight spot, does get it's fair share of dirt on it. That small plastic part carries the weight of the car for the entire corner for that wheel. Quite a job for such a tiny part. It must maintain the link between the upper spring perch and the upper strut mount completely solid plus give it the ability to swivel. When it starts to fail, that link gets lose and it's ability to let the strut turn smothly under the load of the vehicle diminishes.
That $20 part usually corrects most spring associated popping and clunking sounds. They should be replaced every time you change your springs or struts. It's just good insurance that your suspension job comes out right.
Old Mar 14, 2003 | 05:13 AM
Lime's Avatar
sometimes noises are caused by the spring isolators being int he wrong place as well.
kingw323
20
Oct 21, 2015 08:36 AM
MaxStock
Aug 14, 2015 10:01 PM
jholley
Aug 11, 2015 09:38 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
