New T/O Bearing, Trans Seals, STS, and problems...
Old Mar 15, 2003 | 05:26 PM
dmontzsta's Avatar
Ford Only.
I left the shop and the gear shifter is hard as hell to move, even putting it in neutral and wiggling in between, it is stiff as hell, the shifter doesnt even bounce to the middle when you put it in the center.
Anyone else with the STS notice it was harder to shift?
Any comments? Maybe I did something wrong?
Old Mar 15, 2003 | 05:30 PM
NickStam's Avatar
Re: New T/O Bearing, Trans Seals, STS, and problems...
you need to break it in. mine was like that.
Old Mar 15, 2003 | 05:34 PM
dmontzsta's Avatar
Ford Only.
Re: Re: New T/O Bearing, Trans Seals, STS, and problems...
thanks for the reply.
was it EXTREME? my fokin arm hurts from shifting, how bad was yours?
how long was the break in?
Old Mar 15, 2003 | 05:41 PM
NickStam's Avatar
i had a nissan dlrship do it cause it was wintertime. I thought they broke something because it wouldn't move at all. And I didn't have a **** on there because they had to rip the old one off. So It was bad for like 3 days. Then you will gradually get used to it.
Old Mar 15, 2003 | 05:51 PM
Mishmosh's Avatar
If you didn't lube the hell out of the spacer bolt that holds the shifter rod to the linkage, it'll be pretty stiff. Also, most make the mistake of tightening that too tight--you really only need it to be snuggly tight and have threadlock on the threads. In any case, a few month's breakin is all that is required. Also, a liberal amt of lube on the ball is also good.
Old Mar 15, 2003 | 08:00 PM
MaDMaX024's Avatar
more likely than not its hitting your heatshield. i dont have a cat, so i dont have a heatshield, so i dont have any trouble..but my roommate does and its really bad, even with a stiffer return spring it doesnt bounce back to the middle like it should, and shifting is quite a chore even with his set at a longer throw than mine.
Old Mar 16, 2003 | 05:07 AM
Chinkzilla's Avatar
That's why you're supposed to BANG A DENT in your heatshield
Old Mar 16, 2003 | 07:06 AM
MaDMaX024's Avatar
Re: Re: Re: New T/O Bearing, Trans Seals, STS, and problems...
we already did, i guess the next step is the take the heatshield off.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
mpbclutch33
Dec 26, 2015 11:11 AM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
