does anyone know the compression ratio of the vq30de-t from japan???
Old Mar 16, 2003 | 12:38 AM
a33's Avatar
a33
and what other parts are different from our engine????
thanx
Old Mar 16, 2003 | 01:12 AM
hlh0501's Avatar
i have been told 9:1 ....
Old Mar 16, 2003 | 02:04 AM
a33's Avatar
a33
the turbo engine or our engine???
Old Mar 16, 2003 | 02:08 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
the turbo motor
Old Mar 16, 2003 | 03:01 AM
a33's Avatar
a33
Originally posted by DA-MAX
the turbo motor
how about our motor
what is the compression ratio???
and do u know what parts i need if i want to put that turbo into my engine??
do i need the pistons from that engine???
Old Mar 16, 2003 | 09:25 AM
Nealoc187's Avatar
SLOW
Ours is 10.0:1. Talk to Tilleys99, he's done the conversion to DET.
Old Mar 16, 2003 | 10:19 PM
i30krab's Avatar
The VQ30DET definitely has a 9:1 compression ratio. I used the pistons, rings, and valve springs from the DET in my DE. Clark at JWT told me that's all I needed from that motor because the rest of the DE internals are just as strong!
Old Mar 16, 2003 | 10:45 PM
a33's Avatar
a33
so if i have to pistons, rings, valve springs, turbo and exhaust manifold, i can do the conversion right???
how much would it cost??
Old Mar 17, 2003 | 05:04 AM
Whitemax's Avatar
Disco Biscuit
Unfortunately no. Since the VQ30DET is a used in rear wheel drive cars, the exhaust maifold won't work. The blower itself you could probably use, but you have to create custom piping to use it. About the same cost as buing a kit.....
Old Mar 17, 2003 | 08:47 AM
a33's Avatar
a33
ok thanks...
so i guess it will be easier to custom a turbo then...
since it is not an easy job to do the switch...
thanx
Old Mar 17, 2003 | 09:04 AM
DA-MAX's Avatar
has anyone tried fitting them yet?? I'm guessing Tilley did why don't they fit??? ...84-89 300zx turbo manifolds bolt right up for us 3rd gen guys, no fitment issues!!
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
RinconI30
Nov 10, 2015 10:55 PM
londonflu
40
Sep 25, 2015 09:11 AM
Serotta33
Sep 17, 2015 12:14 PM
