Quick Question!!! 5x100 and 5x112 with a +35 offset.
Originally posted by Jeff92se
Maximas support bolt pattern 5 x 114 and 18" X 8" rims. The offset should be in the 35-38mm range. Maybe you can fit less then 35mm but I'm not sure. Center bore was not mentioned but if the center bore is too small(smaller then 66.1 mm) the wheels will not fit onto your hubs. You might be able to get different hubcentric rings though.
Originally posted by PCGuRu2K
You can get away with 35offset on 18's... I have 38offset on my 17's.
the MaxFaq's clearly state what the optimum offset is.. https://maxima.org/maxfaqs/sub_tires...#TiresWheels_5
that *******s never posts anything with sense.. unless he is quoting or repeating someone
WOW you guys are a trip.. I never knew I couldn't ask a question without people getting sarcastic.. I thought this site was to help people out, I guess not. Maybe I should ask my questions somewhere else. Well thanks to the guys who answered me. There was a bid on ebay that a friend of mine wanted to bid on so I needed to know if they would fit. Sorry i may not be maxima professionals like some of you guys.
03-12-2020 12:06 AM
pears
09-18-2015 05:25 AM
