are the 4th and 5th gen clutch or tranny swappable
Old Mar 26, 2003 | 08:22 PM
Krash513's Avatar
Does anyone know for sure if i can swap a 2000-2001 clutch or tranny into my 97 without trouble?
Old Mar 27, 2003 | 12:10 AM
20th maxstyle's Avatar
I want to fit an older trans into mine
Old Mar 27, 2003 | 08:23 AM
Maxman2000's Avatar
It would be nice it you could take the 6spd tranny and pop it into the 2000. It sould work unless the bolt pattern is different and the other things are different.
Old Mar 27, 2003 | 09:34 AM
[maxi-overdose]'s Avatar
an older auto? or manual.
5th gen tranny has stronger internals to support the extra power. are you doing a 5spd swap??
Old Mar 27, 2003 | 09:40 AM
Dreizehn's Avatar
Originally posted by Maxman2000
It should work unless the bolt pattern is different and the other things are different.
Hmmmm okay...
Old Mar 28, 2003 | 05:38 AM
BEJAY1's Avatar
Conecarver
That's exactly what DaveB in TX told me. He confirmed an 00/01 would drop into a 4th gen.
Old Mar 28, 2003 | 07:06 AM
breaux124's Avatar
Do 5th gen trannys come in LSD? Has anyone done a 5th gen 5spd swap into a 4th gen?
Old Mar 28, 2003 | 03:23 PM
BEJAY1's Avatar
Conecarver
To answer the LSD question take a look at a 2001 AE edition.
Old Mar 28, 2003 | 03:43 PM
marcdown20's Avatar
can anyone w/ any credibility tell me if this is for real? cause my tranny is gone now and i'm lookin for a new one...
btw... is there any advantage in goin this route, are they really stronger? i mean our tranny has taken over 400 hp so why would they strengthen the 5th gen's for a measly 32 hp? could the gear ratio's be different?
thanks in advance
mike
Old Mar 29, 2003 | 03:17 AM
I want a five speed but it is hard to find 00-01 front clips. I wanted to know if a 4th gen manual would work at all. A six speed will not work because of sensor which would have to be adapted.
Old Mar 29, 2003 | 03:51 AM
krismax's Avatar
Father of the 00 VI
thanks in advance
mike
2001-2001 gear ratios are the same as 4th gen. And 2 and 5th gears are stronger, thats what my info says.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
