9004 wiring harness upgrade Problems
Old Mar 28, 2003 | 08:45 AM
DaThrillr's Avatar
i recently installed my upgraded harness from southwest autworks and the lights work but they arent bright at all... and my high beam indicator is on very faintly inside the gauge cluster....
anybody know what i did wrong or is that the way its suppose to be?
Old Mar 28, 2003 | 09:53 AM
Flava_24/7's Avatar
Boosted Panda
I had the same problem. They are installed incorrectly. You need match the wires up the exact same way they come out of the harness plug, Dont try to match up the colors. Black from the orig. wires goes to red from the new harness , thats your ground. the others change depending on wich side of the car your on. You should be able to figure it out by pluging them up and seeing wich ones come on. Email me if you need more help and i will go out and look at the plugs and can tell you exactly which wires go together by color.
Old Mar 28, 2003 | 10:04 AM
redmaxpa007's Avatar
i SeE what you did therE
very informative.. i will remember that
Old Mar 28, 2003 | 12:34 PM
Flava_24/7's Avatar
Boosted Panda
UPDATE:
On the factory wiring, driver side has 3 wires, black,yellow, green.Hook the black wire to the red wire on the new harness. The yellow wire goes to the green wire on the harness.Green wire goes to the black wire on the harness.
On the passenger side the 3 factory wires are black,blue, and green.The black wire goes to the red wire on the new harness, the blue wire goes to the black wire on the harness and the green wire goes to green, on the harness.
Hope this helps.
Old Mar 28, 2003 | 12:50 PM
Jepht20's Avatar
Custom User Title...
yeah...i just went through that the other day. at first i thought it was gonna be just matching up wires, but you gotta make sure you look at the old ones where the wires were positioned and match up the same for the new harnesses. it's lame they didn't make the wires the same color but it's not that bad or hard to do or see. mine are now working perfectly, so best of luck fixing yours.
Old Mar 28, 2003 | 04:13 PM
DaThrillr's Avatar
thanx for all ur help guys i will try and let u know...
Old Mar 29, 2003 | 04:46 PM
maximaseefu's Avatar
I have the same problem with mine, however i am confused. I have the 2 relays and the 2 grounds then the harness that plugs into the drivers side plug and then split from there to the 2 harnesses to the bulbs themselves. can someone walk me through this process?
Old Mar 29, 2003 | 07:26 PM
Flava_24/7's Avatar
Boosted Panda
Sounds like you have the apc harness, go to maximadriver.com theres a how to section that has a diagram of the install.
Old Mar 29, 2003 | 08:03 PM
1HOTMAX's Avatar
answer:
throw them out and buy H.I.D
Old Jan 11, 2004 | 03:08 AM
ThurzNite's Avatar
I wouldn't expect the swaw harness to help much, except the fact that the contacts are probably cleaner than your original. The plastic doesn't feel dense or solid and seems unable to withstand any additional heat.
Good luck w/the install.
Jae
Old Jan 11, 2004 | 10:28 AM
DaThrillr's Avatar
GRAVE DIGGER!!! BTW the SWAW has worked much better than the stock i havent chenged bulbs since back in march when i posted this, much better than burning lights every 2 months!
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
boomerbrian
Oct 31, 2018 10:25 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
