shortcut to soldering
Old Jan 10, 2004 | 05:59 PM
sk24iam's Avatar
I was talking to someone from a car audio forum and he says he just uses a glue gun rather than a soldering iron. Anyone ever try this?
Old Jan 10, 2004 | 06:51 PM
Nismo's Avatar
sounds a little ghetto if you ask me. solder ensures a 100% joint. just covering the splice with hot glue is probably just the same as wrapping it with tape
Old Jan 10, 2004 | 07:00 PM
nubiannupe's Avatar
OG Maxima.org Member
A glue gun??? Not only is that ghetto, but it's dangerous. Think, if you will, just how hot it needs to be for glue to melt - even fully cured. Not much. Now, think of how darned HOT the inside of a vehicle gets on a nice summer day.
Whoever told you that, was probably the SAME guy that burns cars up by drilling through harnesses on a regular basis.
Soldering iron/tape is, hands down, the BEST method period. Better connectivity (over butt connectors and the like), and virtually eliminates the chance of wires coming loose (ala the strip-and-splice method)
Old Jan 10, 2004 | 07:30 PM
JeEvE's Avatar
Is the glue gun letting out solder instead of glue or something? I cant believe that someone would use glue to hold a connection.
Old Jan 10, 2004 | 09:25 PM
budha56's Avatar
Yeah, if he uses solder IN a glue gun, that just might work...never thought of it before though.
Old Jan 10, 2004 | 11:01 PM
Maxtank's Avatar
ummm...i don't really see the point, you still have a device what can burn and melt solder....although i suppose it would be easier to apply to wires....
Old Jan 10, 2004 | 11:14 PM
packetattack's Avatar
That's not recommended at all. All of my joints/repairs always use solder or SpliceLok connectors.
Old Jan 10, 2004 | 11:28 PM
Maxima95Tuner
If you guys notice, when solder melts, it turns nearly to liquid. Glue guns have to force the glue stick out when it's melted. Solder would just shoot out of the gun, or drip out.
Glue is definately way too ghetto. It's like trying to hold wires together witih a piece of gum.
Old Jan 11, 2004 | 01:44 AM
† ErV †
i've tied and wrapped plenty of large wires.. no problems yet.
but you sure it's not the silicone gooey stuff the phone company uses on their phone jacks and wires? that wouldn't hold anything together but it provides a very nice shielding against water and debris.
Old Jan 11, 2004 | 02:20 AM
Nismo's Avatar
I think your talking about that liquid electric tape. I dont think you want that stuff anywere around your car
Old Jan 11, 2004 | 02:43 AM
hakk97se's Avatar
You could never stick solder in a glue gun. That's just retarded. The tip of a soldering iron is typically about 600 degrees. You're not going to get solder hot enough with a glue gun. Second, any engineer world half a salt (hopefully me included) will tell you that soldering is not exactly the process of "dripping" solder onto a connection.. You need to make a bond with the wires by getting them hot enough to attract the metals in the solder. Dripping solder on a cold wire does not make as good a bond. If you are talking about audio wires, you want the best bond you can get.. not just for strength, but also to minimize interference..
Old Jan 11, 2004 | 09:22 AM
Maxima95Tuner
Well said.
Old Jan 11, 2004 | 03:46 PM
Zero Deuce SE's Avatar
I would go with soldered splices and heat shrink tubing.
AaronL
Nov 15, 2020 11:52 AM
dcardello
Sep 3, 2015 11:44 PM
Gary95
May 16, 2002 11:45 AM
Sexima
26
Jan 4, 2002 10:26 PM
AC439
Jul 8, 2001 11:25 AM
