Checked my vacuum today...
Old Mar 31, 2003 | 11:59 AM
Soon2BMaxed's Avatar
As some of you might know...i made a thread awhile back about how "slow" my car has felt lately. it started feeling like this a few monthes ago when i got the CEL for the EGR temp sensor. i reset the ecu, didn't change the sensor, and the light never came back on but the car has felt slower ever since....
fast forward to today.....i check the vacuum and its at 22psi but flutters between 22 down to 21. i dont know if that is normal so post your thoughts.
i also noticed something else. i've always had this constant "ticking" noise that sounds like a clock. well if you have the car on and completely warmed up, you can put your head down by the filter and hear this "Tick, bump bump, Tick, bump bump"
i also hear the EXACT same noise when i check the ECU for codes. why would it be doing this while the car is running? i usually only hear that noise when i turn the screw on the ECU to the bumpstop to get codes.....
Old Mar 31, 2003 | 12:42 PM
Dave B's Avatar
Not DAVEB the parts guy
Re: Checked my vacuum today...
I forgot to tell you to make sure your engine was full warmed before checking the vacuum because the fast idle seems to influence vacuum and may cause it to bounce a little. If the vacuum is slowly changing between 21-22, I doubt there's any problem.
As for the ticking, I hear it too when I'm checking codes on the ECU.
As for your cars absolute lack of power, here's something to consider. Your car has had a ton of down time lately. Haven't there been multiple instances where you've reset the ECU and/or disconnected the battery? I can tell a HUGE difference in part-throttle and WOT acceleration (lack of) when I've either reset the ECU or unplugged the battery. It seems to take 3-4 days before the car finally feels like it's back to normal. How many days did your car run between problems?
One of these days I'll have to drive your car and I can give you my opinion.
Dave
Old Mar 31, 2003 | 12:53 PM
ejj's Avatar
ejj
My vacuum normally is around 20in-hg at idle. After shifting it will drop to about 22in-hg.
Old Mar 31, 2003 | 02:47 PM
car was completely warmed up.
my car would go a few days or so without my mechanic driving it for more than 10-15 minutes at a time. i tried reseting the ECU and it didn't change anything.
Old Mar 31, 2003 | 08:22 PM
Dave B's Avatar
You've got to give a few days of solid driving (lots of start ups), at least.
Dave
Old Mar 31, 2003 | 08:26 PM
Dave
i did that i just did it a couple weeks ago actually....
Old Mar 31, 2003 | 08:52 PM
Requin6's Avatar
i also have the ticking. it ticks every second it seems. i dont seem to have a loss in power, but i didnt hear it/notice it prior to putting the VI on. its not loud or noticable, but if you are very picky like me and listen to the motor like a stereo...then you can hear it
--Paul
Miket2006
Mar 1, 2021 03:55 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
homewrecker
Sep 24, 2015 07:01 PM
