bodyshop turned my car PINK.. HELP !
Old Apr 4, 2003 | 01:57 PM
hokiemax's Avatar
I brought my car back from the bodyshop ( I needed a new hood), and guess what. There are micro sized pink particles, or dust, or paint droplets, whatever you wanna call it, its all over my car. Its not so obvious at first sight, but when you touch the car, its very scratchy, and from a certain angle, the car LOOKS FRIGGIN PINK... I'm so ****ed.. how do I get this stuff off? Someone mentioned using a meguiar clay bar or something.. detailing experts, please help. thank you.
Old Apr 4, 2003 | 02:00 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
Re: bodyshop turned my car PINK.. HELP !
wtf
Bring the car back and b i t c h at 'em
Old Apr 4, 2003 | 02:02 PM
deezo's Avatar
You may just need to compound it. Do one spot first to see if it comes off easily. If not take the car back to them. Look in my sig for what I use which is 3M.
Old Apr 4, 2003 | 02:03 PM
SR20DEN's Avatar
VQ Wizard
Admit it you wanted a pink car.
Old Apr 4, 2003 | 02:07 PM
RBa's Avatar
RBa
Re: Re: bodyshop turned my car PINK.. HELP !
Be proud for you're the 1st ever with a pink maxima..
Old Apr 4, 2003 | 03:28 PM
scmaxima2k's Avatar
Old Apr 4, 2003 | 03:34 PM
Sprint's Avatar
Re: Re: Re: bodyshop turned my car PINK.. HELP !
redmax might take offence to that
Old Apr 4, 2003 | 03:45 PM
thebigsadler's Avatar
Re: Re: Re: Re: bodyshop turned my car PINK.. HELP !
jeff has a had a pink max for years..
Old Apr 4, 2003 | 04:00 PM
NickStam's Avatar
pics
Old Apr 4, 2003 | 05:20 PM
gtr_rider's Avatar
192.168.1.1
jeff must be proud
Old Apr 4, 2003 | 05:32 PM
Vyrus's Avatar
Originally posted by gtr_rider
jeff must be proud
Nah he's afraid to come out of the closet so he expresses his feelings through his car..
Hokiemax you should be able to take it out with Rubbing Compound or Meguiar's Clay Bar (probably should try this one first), but if I were you I would take it straight back to the shop. No need for you to spend hours working on the car when it's not your fault.
-Cyrus
Old Apr 4, 2003 | 05:34 PM
erty67's Avatar
Decal Specialist
go back to the body shop and let them fix it. If they can't.....new paint job!
Old Apr 4, 2003 | 06:14 PM
Donkey®'s Avatar
wat
Old Apr 4, 2003 | 06:15 PM
gtr_rider's Avatar
192.168.1.1
-Cyrus
His married with a little girl racer though
Old Apr 4, 2003 | 09:05 PM
-MaxPayne-'s Avatar
It's most likely overspray (but wtf, painting pink?) Your best bet would be to use the clay bar, but if that doesn't work make those idiots get it out.
-Payne-
Old Apr 4, 2003 | 09:08 PM
SR20DEN's Avatar
VQ Wizard
Originally posted by look2me40
I'll have to add that one to my collection.
Old Apr 4, 2003 | 09:17 PM
nadir_s's Avatar
vicodin ... gift of life
don't spend a freakin minute trying to fix the problem yourself. drive back to the bastards and tell THEM to fix it.
Old Apr 4, 2003 | 09:30 PM
iansw's Avatar
Yeah, screw that - make them spend hours on it with a clay bar....you shouldn't have to.
Old Apr 5, 2003 | 07:10 AM
tomj's Avatar
I know this sucks, but I wouldn't bring it back to them. If they can't spray correctly what makes you think they will fix your car correctly. I wouldn't trust them. Do it yourself.
Old Apr 5, 2003 | 07:24 AM
99maxi's Avatar
i would just bring it back and have them compound it.. overspray is hard to control but a good body shop would compound and buff the car just before u go pick it up..
Old Apr 5, 2003 | 08:27 AM
fisher01's Avatar
Not only would I take the car back, I would stay there and watch them every minute. If the clay bar will work, it will be much less abrasive on the paint. I certainly wouldn't want the body shop to use an abraisive rubbing compound to quickly remove the overspray.
Old Apr 5, 2003 | 08:58 AM
N34JZ's Avatar
Needs non-Maxima Friends
yeah its probably overspray, take it back, they can get it out, someone probably was painting red near your car and your car wasnt covered.
Old Apr 5, 2003 | 09:13 AM
redmaxpa007's Avatar
i SeE what you did therE
jason, darren and the others..
Old Apr 5, 2003 | 09:40 AM
deezo's Avatar
Old Apr 5, 2003 | 09:41 AM
Originally posted by deezo
and YOU TOO
Old Apr 5, 2003 | 09:42 AM
joaquink's Avatar
¿Hablas Español?
Yep yep yep - that's what clay bars are intended for. You shouldn't spend any time getting the overspray off. Wish I had remembered to get a picture of the 96 Maxima my neighbor repossessed from some - it was intentionally repainted bright pink.
Old Apr 5, 2003 | 12:07 PM
N34JZ's Avatar
well if you cover the other cars that your not painting or spray in a booth its not.
Old Apr 5, 2003 | 04:04 PM
Matt93SE's Avatar
STFU n00b!
As everyone else said.. you didn't cause the problem, THEY did. let THEM fix it. they'll have the buffing and polishing equipment necessary to clean it up quickly and properly. don't waste a second on it yourself. just call them up and tell them it's got overspray all over it and make an appointment for them to fix it.
Old Apr 5, 2003 | 08:02 PM
Chinkzilla's Avatar
First of all, meguiars clay sucks. Try mother's or clay magic. Secondly, most retail grade clay bars are meant for mild overspray situations or removing road contamination. You may have to step up to a professional cut clay for this situation. I strongly urge you to post your problem at www.autopia.org and let the experts there take care of it.
Compounding your car will NOT help. It is for removing surface imperfections not, stuff ON the surface. Think about it, you're taking an abrasive compound and working a layer of your clear coat off. All the while you are rubbing in these micro droplets of dried pink paint deeper into every crack and crevice of your finish. The proper procedure would probably be to clay the car, then go over with a light cut polish to restore the finish, and cover it up with a wax.
I would not take it back to the same shop if I were you. Obviously they do not have the 'show car' mentality. I would make them aware of the problem, take photographs. And then go to a professional detailer and attempt to have him fix the problem for you. Afterwards, I would bring pictures of the 'after' and an invoice with you back to the original guy who screwed you, and make him reimburse you. If he refuses, threaten to file a BBB complaint and pursue a civil suit.
Good luck.
Lakersallday24
Jun 16, 2019 01:35 AM
beboski
Aug 16, 2015 05:23 PM
MikesChevelle
Aug 9, 2015 11:50 AM
egali045
Aug 5, 2015 09:02 AM
