giovanna drama 21s
Old Apr 9, 2003 | 10:45 AM
MJE's Avatar
MJE
giovanna drama 21s
i think 2 of you guys said they will fit on my 2k3...what mods if any would i need...and whats the bolt pattern?
Old Apr 9, 2003 | 11:26 AM
MJE's Avatar
MJE
i just did the math, it said the 21s with the tire package they come with have an outer diameter of 28.14 inches...would that fit??
Old Apr 9, 2003 | 12:48 PM
max'n out's Avatar
check the tire size of a 245-35-21...Should fit, measure side to side...meaning from door jam fender to other side of the fender toward the side marker.
Old Apr 9, 2003 | 01:33 PM
Phoenix1911's Avatar
Yikes... The stock 225/50/17s measure 25.9 diameter... If you've dropped the car forget it. If you haven't dropped the car I still doubt they will fit. To be 100% sure your best bet would be to jack it up by the suspension, pull the wheel off and measure EVERYTHING...
Old Apr 9, 2003 | 03:25 PM
MJE's Avatar
MJE
so 20s are probably the maximum huh??
found those giovanna dramas with 255/35/r21's on them brand new for 2150 on ebay.
they retail for 1195 per rim which amazes me.
Old Apr 9, 2003 | 03:27 PM
max'n out's Avatar
Measure it and find out, whats the offset and wheel lug patern on um?
Old Apr 9, 2003 | 03:44 PM
MJE's Avatar
MJE
what bolt pattern do i need?
Old Apr 9, 2003 | 03:49 PM
max'n out's Avatar
114.5 x 5 with an offset around 35-40mm
Old Apr 9, 2003 | 04:00 PM
KsuMax's Avatar
Cheesing away...
any pics?
Old Apr 9, 2003 | 04:13 PM
lsondubz's Avatar
killer deal, just saw that, almost to good to be true
Old Apr 9, 2003 | 04:41 PM
MJE's Avatar
MJE
so would these things fit?? or would i have to modify the car?
Old Apr 9, 2003 | 04:47 PM
MJE's Avatar
MJE
and what about when i turn the wheels??? is it going to rub?
Old Apr 9, 2003 | 04:51 PM
max'n out's Avatar
I looked on Ebay and found them, I see he has five sets, that strikes me very oddly.
112 is not going to fit you'd have to get them re drilled. Thats the first thing.
Offset looks fine sount' rub, but it's all coming down to wheather or not it clears the way i told you to measure.
Old Apr 9, 2003 | 05:02 PM
MJE's Avatar
MJE
what about his one set of dramas that he has they are 114.3 offset he says with 38mm.
Old Apr 9, 2003 | 05:08 PM
MJE's Avatar
MJE
29.5 from wheelwell near door to sidemarker wheelwell ending. give or take 1.8 of an inch. i know i factored the rims are 28.14 inches with tires that come with them. whaddya think...i dont remember how to calculate how much space the rims would take up corner to corner...id think they'd rub when i turn.
Old Apr 9, 2003 | 05:19 PM
max'n out's Avatar
I guess I missed the offset of the one that said 114.3
Take your wheels off...Take the tape measure and center it and spin it, that will tell you if you will clear. Or make a card board cutout that will tell you some.
Old Apr 9, 2003 | 05:31 PM
MJE's Avatar
MJE
so i just went outside...it cleared when i put a 28.2 inch cut board from the middle of the wheel spindle, and spun it by hand...the top only cleared by like 1/6th of an inch...wont suspension travel screw me over? also i dont understand the whole turning thing. i know wheels when turned will be even wider than the 28.14 inches (diagonal to diagonal measurement) and probably rub..if it was you, would you just stick with 20s or would you attempt to put 21s on it.
also do i have to measure from the actual spindle with the wheel off to get the most accurate measurement...cause i think id get much more room with the wheel off if i measured from the spindle center (mainly tire compression from the weight).
thanks for all your help
-MJE-
Old Apr 9, 2003 | 06:07 PM
lsondubz's Avatar
as far as 21's fitting, you might be able to pull it off w/ a low pro tire, 35 series, i'm guessing you might have to roll your fenders
http://www.20inches.org/cars/morgan.htm
I'm not sure what mods he had to do to get them on his 4th gen, i believe he used to be on this forum, maybe someone remembers
Old Apr 9, 2003 | 08:25 PM
Blk2kMAXSE's Avatar
I think it would fit but it would definately rub. I have 20x8.5 w/ 255/35 rubber and i rub a little when i turn.
Lam
Old Apr 9, 2003 | 09:44 PM
BOZOnPJs's Avatar
those rims are not for the maxima
Old Apr 10, 2003 | 10:46 AM
1/6" clearance... wow.. Pull all your suspension out and replace it with cement blocks! Your rides going to be a little rough, but those 21s will look sweet...
honestly its a lot of money to gamble on, and i REALLY don't think they will fit... Hell they may have a hard time fitting some trucks!
Old Apr 10, 2003 | 05:44 PM
MJE's Avatar
MJE
this is a sad day in buzzards bay...
the guy emailed me and told me "the rims will fit without any modifications to your vehicle..." thats just what i needed to read jesus h christ i hate my life. cause i feel like ill put 20s on it, and then ill realize i could fit 21s knowing my luck and ill pass up this awesome deal
Old Apr 10, 2003 | 07:26 PM
lsondubz's Avatar
i don't know about without any modification... i have a lincoln ls which has a larger wheel well than a maxima.. and i need to at least roll my fenders.... he also said they would fit on my car, yet the local rim shops are telling me no.. so i don't know if i trust him to much.. just a heads up
serin
Dec 17, 2002 07:03 PM
brodaiga
May 12, 2002 04:08 PM
2001semax
Jan 22, 2002 07:48 PM
ghettomaximaz
Nov 16, 2001 07:09 PM
rocketshipon19"
Oct 8, 2001 09:38 PM
