Electric al System in question
Old Apr 14, 2003 | 08:41 AM
ADNY's Avatar
I am thinking there's a short in electric system. Doesnt seem to affect overall use-ability of vehicle with any identifiable pattern (sits a week and starts, perhaps its draining only when car is on?)
My Haynes manual states ‘To test a short, disconnect negative battery terminal, put a light across terminal to negative clamp. With ignition key off, theres a short if light comes on. Huh, according to this procedure I have a short?
They direct u to pull each fuse to identify branch circuit in question(light should go out). My light always gives a positive result. Something is not right here? This Haynes method seemed relatively idiot proof.
Questions:
Isn't there always a drain on circuit(ie: clock?).
Can you have a short in Alternator and still function
Are there any better approaches to this problem?
ADNY(aka the idiot)
Old Apr 14, 2003 | 08:53 AM
kushane's Avatar
The clock, radio and ECU always draw small amounts of current for holding presets, setting etc. You can remove fuses for the clock and radio. On my Mazda - I used to just disconnect the cable fo the ECU and then check for any current drain. This should work on the Max too..
Old Apr 14, 2003 | 11:39 AM
ADNY's Avatar
The plot thickens
Thanks K for the info. But I can only guess about its location (manual brlliantly indicates via pictures that thru 88 it was under front seat and after that it was under dash... but it doesn?t indicate were?
Don?t suppose you know, any ideas on which wire to pull?
ADNY
Old Apr 14, 2003 | 11:46 AM
njmaxseltd's Avatar
Re: Electric al System in question
ADNY(aka the idiot)
ADNY (aka the idiot)
I fail to see any problem with your car. Why are you performing this test in the first place?
What makes you think there's a short someplace? Plus you go futther to say it doesn't seem to affect the overall useability of the vehicle and it even starts after it sits a week?
Tom (aka the curious)
pktaske
May 6, 2016 07:49 AM
dcam0326
Sep 7, 2015 07:26 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
