relay check how ..!!
Old Apr 24, 2003 | 07:01 AM
maximalover's Avatar
Hi Guys,
I have a 93 Maxima SE. I wanted to check one of relays in there works or not..
it is a blue one... it has four pins and I guess it is normally open. and numbers i see on the relay are
1 - 2
3 - 5
I have the FSM and it says if I supply current to 1 and 2 then 3 and 5 should be closed (or pass continuity test)
I have access to 12 volts power supply.. (at work) and a multimeter.
I want to know how can I test this..? Should I just connect 1 and 2 to 12volts power supply and check continuity between 3 and 5..?
How long do these relay last...?
I will appreciate your reply...
Old Apr 24, 2003 | 08:48 AM
xHypex's Avatar
Re: relay check how ..!!
Originally posted by maximalover
Hi Guys,
1 - 2
3 - 5
Looks like these right
Close. You need to supply +12V to either 1 or 2 (it doesn't matter). Then supply ground to the terminal you didn't use i.e. if you put +12V on 1 put ground on 2.
Wire it up as I stated above. You'll hear the relay click when you put +12V and ground on 1 and 2. You should have continuity between 3 and 5 when the relay clicks. If you don't hear clicking then your relay is probably bad. If you don't have access to +12V I use 9 Volt batteries all the time to check things like relays (9 volts is close enough to check to make sure something works).
A long time. Most people never have to replace relays as they're pretty simple internally
http://electronics.howstuffworks.com/relay1.htm
-hype
Old Apr 24, 2003 | 08:49 AM
Stephen Max's Avatar
Hi Guys,
1 - 2
3 - 5
1) 12V supply to pin 1.
2) ground to pin2.
3) check continuity across 3 and 5 with ohmeter.
You should be able to hear the relay make a clicking sound when you energize it with the 12V source.
Old Apr 24, 2003 | 09:56 AM
Re: Re: relay check how ..!!
Hype
That was much more than I expected....(oh ..man with large picture and explanation).
Thanks a lot...
Old Apr 24, 2003 | 11:40 AM
«§»Craig B«§»'s Avatar
an easier way to test is just swith the relay in place of another blue relay for a system that you can easily check - parking lights, horn, whatever
Old Apr 24, 2003 | 12:06 PM
Huh. Simple, but elegant. I like it.
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
