Sumitomo HTR+ tires...loud?
Old May 14, 2003 | 02:13 PM
Cumalot's Avatar
Do you guys think Sumitomo HTR+ tires are loud? I just put them on less than a week, but I noticed when driving, the tire noise was very apparent. Also, I want to make sure of something. The HTR+ tires are non directional right? What I mean is they can be mounted either on the left or right.
Moderators: please delete my other thread. Tks.
Old May 14, 2003 | 02:30 PM
kj043's Avatar
Re: Sumitomo HTR+ tires...loud?
I've had my Sumitomo's on for a month now and they aren't loud at all imo. To answer your other question, (from tirerack.com): One of the benefits to the Sumitomo HTR+¡¯s symmetric tread design is that it allows traditional tire rotation patterns to be used (this promotes even tread wear and helps prevent tire pattern noise increases that would accompany uneven tire wear).
Old May 14, 2003 | 08:34 PM
Dave B's Avatar
Not DAVEB the parts guy
Yes, the HTR+s will be loud for about the first 500 miles. After that they get significantly quieter and stickier. I wonder if it has something to do with their heat cycling.
Dave
Old May 14, 2003 | 09:03 PM
Cumalot's Avatar
Dave
That's good to hear.
Old May 14, 2003 | 09:19 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
I have not noticed any noises with my htr+ since day 1. But that can be that I came from the stockers, so these tires are alot better then what I had prior.
Old May 15, 2003 | 01:10 AM
NyC97Max's Avatar
theyre really loud when braking hard from high speeds, they make a whirling sound almost like a jet turbine...but the slight noise it makes during normal driving i think is nice, gives them a bit of attitude
Old May 15, 2003 | 04:32 AM
Triple8Sol's Avatar
I miss the .org!
Another thing too, when you plus size, and get a thinner sidewall, road noise also increases...
Old May 15, 2003 | 12:21 PM
20th maxstyle's Avatar
Try the Dunlop SP500's next time. Might not last as long but man do the stick to the bitter end. I have 245/45/17. WARNING- do not go with the Yokahama A550 of AVID 4's. They suck. Next set is going to be the Bridgestone Potenza S-03 Pole's. Once you go S-03, you never go back.
Old May 15, 2003 | 01:19 PM
Cumalot's Avatar
The next time I think I'm going to just spend the extra money and get the Toyo T1-S tires. Plus they are super light. With my 17s and the HTR+, the combo only weighs in at 38lbs. That's pretty good already, but I bet with the T1-S, it will be even lighter.
Old May 15, 2003 | 03:38 PM
maxnomo's Avatar
Where can I find tire weights?
THEKNITE
Feb 23, 2003 12:15 AM
THEKNITE
Feb 22, 2003 04:51 PM
THEKNITE
Feb 20, 2003 11:53 PM
Kevin
Dec 20, 2002 10:35 AM
