Service Engine Soon Light
Old May 17, 2003 | 07:02 PM
SnOwBoaRdRXX's Avatar
I would have searched for this answer, but the site isn't letting me.
The Service Engine Soon light came on, the manual says it might be something with the exhaust.. What should I do? Check the ECU? Anyone have a link to that ECU code page?
-Craig
Old May 17, 2003 | 07:15 PM
patel_anu's Avatar
Re: Service Engine Soon Light
-Craig
http://forums.maxima.org/showthread.php?threadid=104931
Old May 18, 2003 | 03:08 PM
Alright it says my crankshaft position sensor is the problem.. That bad?
Old May 22, 2003 | 03:24 PM
Found out my problem.. I apparently had an aftermarket gas cap.. It triggered the sensor.. Figures..
Old May 22, 2003 | 04:46 PM
njmaxseltd's Avatar
If the code you pulled from the FAQ thread indicates your Crankshaft Position Sensor is at fault, your gas cap would not have triggered that.
There are 2 crank sensors, one is called POS for position and the other is called REF for referance. Make sure you know which sensor the code points to. REF looks at the lower crank pully and POS looks at the flywheel.
A lose or defective gas cap will set an EVAP code.
vingodine
45
May 21, 2016 12:46 PM
rbaker100
Aug 28, 2015 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
