cb radio
Old May 21, 2003 | 08:17 PM
David89Max's Avatar
cb radio
ok guys i want to install a cg radio in my max. now i have no clue on doing this. I know i need a cb radio but i dont know what else i need. Damn do any maxima members have cb radios
Old May 21, 2003 | 08:27 PM
SR20DEN's Avatar
VQ Wizard
You want a legal CB or other?
Old May 21, 2003 | 09:02 PM
96BLUMAX's Avatar
You need that and a huge antenna and then your all set. Why do you want one by the way?
Old May 21, 2003 | 09:40 PM
Nismo's Avatar
why not a handheld?
Old May 21, 2003 | 10:32 PM
luckee2bhere's Avatar
you dont need a huge antenna...you can get a very small one but it wont go far...less than 5 miles... go small
Old May 21, 2003 | 11:43 PM
drewm's Avatar
Originally posted by Nismo
why not a handheld?
I've got one, and you can take off the flexy antenna and hook it up to a big one that sticks on top of your car. It's the best.
Old May 22, 2003 | 01:04 AM
MrGone's Avatar
I just bought a cobra handheld for the max.
I also just found my old CB from our familys old 80's Chevy C1500 pickup (with camper). My sister wants me to install a PA on her car, I think I just found a use for the old CB
MrGone
btw, for cars, flexable antennas are good, and you can even bend the mount that comes with it to hug a side window, so you can take it off when your not using it.
Old May 22, 2003 | 04:38 AM
ZuMBLe's Avatar
If you want maximum performance you will want a trunk mount rather than a magnet mount antenna. The trunk mount will require you to chip off some of the paint under the trunk so the mounting screws can get a good ground. Do yourself a favor and get a 1/4 wave antenna. K40 and Wilson make good base loaded antennas. A full wave length whip is almost 9 feet high for 27mhz (CB frequency) that would work the best. You'd look pretty stupid though. If you're just using the CB to listen, anything is fine. If you have a nice rig that you want to protect, you want to get a SWR meter to make sure your antenna is tuned right. Otherwise bye bye transmitter section of radio. What are you going to use this CB for? I'd recommend getting a scanner or using FRS radios if you want to talk between cars.
www.copper.com
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
mikeg75
Nov 30, 2015 05:12 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
