Whining Max
Old Jan 24, 2001 | 11:58 PM
black97max's Avatar
My Maxima is whining all the time. The car whines at idle and gets lounder under accerleration. I brought it to Nissan and they said the alternator tested out fine. I also noticed that when I acclerate my headlights dim so something is draining my power. I need some maxima.org help with this one. Thanks
Old Jan 25, 2001 | 02:11 AM
ZuMBLe's Avatar
Might want to take it to some other dealership and have the alternator checked. You have a 97. 97s have been known to have alternator problems. The first dealership I took it to. They said it was fine. They charged me for belt adjustment. The sound wasn't as loud after that. Months later. My alternator burst into flames.
ZuM
Old Jan 25, 2001 | 02:24 AM
2FAST4U
Okay......so you say your Maxima is "whining" all the time...even at idle. I figure you mean it "whines" even when it is at a stand still (park/neutral)and the noise is coming from under the hood. If this is the case than I suggest you try this little trick: take a tube of some sort,
preferably plastic or rubber (hell a broom handle will even work) about 3 feet in length, start your engine and open the hood.....place the tube on the alternator, water pump, power steering pump, air conditioning unit, etc.(one at a time of course )and the other end on your ear. This is a crude version of a mechanics stethescope (you know...like a doctor uses). You will know when you have found the culprit by the change in sound. Also shut her down and check the tension on any and all belts. Also take your battery somewhere to be checked as it may be going bad and causing unnecessary strain on your alternator. Good Luck!
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
homewrecker
Sep 24, 2015 07:01 PM
