When I installed my Y pipe ~ 2 years ago I put in a new gasket between the Cat and Y. My Cat has been off a couple of times since then for various projects. Last time I took it off I put some exhaust sealant (something with copper in it) on both sides of the gasket before I put it together. This time I put it together without the sealant and now my exhaust is leaking between the cat and Y-pipe. The Gasket is looking pretty beat.
Will putting more sealant around the gasket fix the problem or should I just get a new gasket? If I get a new gasket can I buy one at an auto parts store or do I have to go to the dealer? Is the Dealer going to rip me off on one of these? (Trick question, my local dealer rips me off on everything
)Thanks, do I have to go to the dealer or can I get one at an auto parts store? Do I have to buy a specific one for the Max or do the have universil ones that will work? What size?
Quote:
Originally posted by 96shogunmax
2.5 inch with two holes. Go to any autoparts place.
EDIT - Should I throw some sort of sealer on there too, or will it be a waste with a new gasket?
EDIT AGAIN - Found the stuff I already had, 'Ultra Copper' - Sensor safe high temperature gasket maker
If you plan on taking the cat/Y juncture apart periodically, I think the gasket sealant only makes things worse. Personally, I have had no problems with the OEM gasket which is some 3-4 layers of thin metal. When it appears to be rusted, I would swap it out. As was said, it is cheap and the dealer usually has this item in stock.
