Engine Stand Question
Old Jun 2, 2003 | 12:09 PM
ejj's Avatar
ejj
Anything special needed in an engine stand for a VQ30? Will any one do (assuming its rated for enough weight)?
Example: http://www.jegs.com/cgi-bin/ncommerc...63&prmenbr=361
Old Jun 2, 2003 | 12:28 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
You need an engine hoist (too).
Old Jun 2, 2003 | 12:33 PM
ejj's Avatar
ejj
I'm well aware of that.
Old Jun 3, 2003 | 10:26 AM
ejj's Avatar
ejj
TTT...engine got here today.
Old Jun 3, 2003 | 10:33 AM
Jeff92se's Avatar
I'm needing a caw
I don't think you need anything special. Those stands are clearly rated high enough weight wise. Kevina is right about the hoist thing. You will need one to take the engine out and to lift it up high enough to get it on the stand. But since you're not doing any "serious" work on the engine why get one anyway? Just rent/buy a cherry picker(hoist) and work on the engine that way.
Old Jun 3, 2003 | 10:40 AM
ejj's Avatar
ejj
Well, if I'm going to work on this engine (seals, water pump, etc) I'd feel more comfortable if its on a stand. Also, when I get the old one out I'm going to tear it down to see what happend inside.
[EDIT]
Thanks Jeff.
[/EDIT]
Old Jun 3, 2003 | 10:44 AM
Jeff92se's Avatar
I'm needing a caw
I worked on mine with the engine just sitting on a pallet. But when I needed to get the oil pan off, I just cranked up in the air(dad has a pulley system in the rafters).
Question. How are you going to replace the rear main seal with the engine on the stand?
Old Jun 3, 2003 | 10:50 AM
ejj's Avatar
ejj
Doh!
Good point. I didn't know which end the stand connects to (front, rear), but I assumed it was the rear. I guess that would make that tough, huh?
Regardless, I'm going to look into renting/buying both. I knew any hoist would work, but didn't know how the stands "worked".
Old Jun 3, 2003 | 10:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally posted by ejj
Doh!
the stand have "legs" that goes into the tranny bolt holes at the rear of the engine. pretty much it..then you can turn it and flip it over and etc.
Old Jun 3, 2003 | 11:03 AM
ejj's Avatar
ejj
That was what I suspected.
So now my question is...are those bolt holes universal, or are the stands adjustable?
Old Jun 3, 2003 | 11:17 AM
DanNY's Avatar
Ad·min·is·tra·tor
those bolt holes are NOT universal.
depending what kind of stand u have..u might need to buy long bolts to or you may be able to get away with using the tranny bolts.
adjustable...they usually just turn..the legs are adjustable on where it bolts up to the motor.
Old Jun 3, 2003 | 11:36 AM
ejj's Avatar
ejj
That's what I was wondering. Thanks.
Old Jun 3, 2003 | 11:57 AM
deezo's Avatar
It'll be lovely to install your SC with the engine out of the car.
Old Jun 3, 2003 | 11:59 AM
ejj's Avatar
ejj
So much easier.
Old Jun 3, 2003 | 01:19 PM
DanNY's Avatar
Ad·min·is·tra·tor
So much easier.
why just SC..go all out for turbo since the motor is out.
Old Jun 3, 2003 | 01:21 PM
ejj's Avatar
ejj
I just happen to have a SC lying around.
MAXSE5SPD
Sep 17, 2022 04:00 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Hawkeye61
Aug 12, 2015 06:45 PM
