Electricians help wanted!!!!--->>>
Old Jun 3, 2003 | 11:47 AM
190hpKiLLA's Avatar
Granny Driven
___________________
I I
I I
I__________________I
--Refering to the long fuse box by the left fender.
Would the car start if the 2 boxy fuses were blown in that box?
The problem is this...
My headlights were robbed and the RELAY box(the one by the left headlight) wires were cut.
I did not notice that at 1st and tried to start the car.
When i realized that they were cut I rewired everyhting carefully and taped it off nicely.
THE CAR dont start cause I didnt see the fuses blown. I checked all the fuses and found 4 blown. 2 of which are 15v which i replaced. Then there are 2 more which are a little boxy but not as big as the RELAY ones.
So would the car not start if 2 fuses are blown under the hood or its something I did not rewire carefully enough?
Old Jun 3, 2003 | 01:32 PM
xHypex's Avatar
I don't know how your car is specifically, but what you're talking about are fusible links. Some aren't needed like the power windows/locks, but the ignition also has a fusible link in the panel. If you blew that many fuses you may want to check the fuses inside the car as well to see if any of them blew. A FSM wiring diagram would help speed things along and help you isolate the circuits.
-hype
Old Jun 3, 2003 | 01:42 PM
luckee2bhere's Avatar
slizan99 might know
captchaos
Mar 15, 2016 12:18 PM
ef9
Sep 5, 2015 11:18 PM
Maxboy23
Sep 4, 2015 06:04 PM
jds22
Sep 4, 2015 01:52 PM
crazyespn
Sep 3, 2015 01:30 PM
