misfiring
Old Jun 5, 2003 | 03:27 PM
asf4life's Avatar
misfiring
i just changed my spark plugs, i was ddumb enought o use the bosch 2 plugs cuz htey were about $6 cheaper/plug, anyways, my car is misfiring now, while i was driving my check engine light was flashing, i think it flashed 5 or 6 times, wat does that mean, is it $ 5 or 6 spark plug misfiring, i cant check those 2 plugs right now cuz the engine is hot, but the other one si already checked what do u guys receomend i do
Old Jun 5, 2003 | 03:44 PM
Kevlo911's Avatar
Kevlo for President
wat year max?
Old Jun 5, 2003 | 03:45 PM
asf4life's Avatar
98
Old Jun 5, 2003 | 03:59 PM
I30tMikeD's Avatar
you need to pull you CEL codes.....
Old Jun 6, 2003 | 08:22 AM
asf4life's Avatar
my #5 cylinder is misfiring, i figured it was that one, well i might have to buy a new ignition coil which is like $60, but w/e as long as my car works again. im not sure if its the coil it self, i want to check if it is receving power from the harness but i dont got no volt tester. i probably got one sitting around somewhere. ill let you guys know what happened
Old Jun 6, 2003 | 01:51 PM
asf4life's Avatar
ignition coil is good, one of the pins o nthe harness was bent, engine is runnig fine now, thank God
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
