Clutch Chatter??
Old Jun 6, 2003 | 04:03 AM
Victim64's Avatar
Clutch Chatter??
Just curious what this actually is? Is it a noise the clutch makes, or is it just a vibration? Also, is it harmful?
Thanks!
Old Jun 6, 2003 | 07:50 AM
Victim64's Avatar
I know there are people out there that have experienced this, if I could search I think there would be tons of threads on it. thanks for help!
Old Jun 6, 2003 | 08:11 AM
PiotrC70's Avatar
I've heard it has to do with the flywheel not being properly cleaned and the pressure plate side of the clutch not being properly clean. (not the actual clutch itself) Basically if there is grease or the protective coat on the clutch that the manufacturer puts on, it could result in chatter. If you're the one doing the clutch job, spray brake-clean on parts mentioned above and to help, you can take an scotch-brite pad to it but rub in an even motion, don't concentrate on one single area.
Old Jun 6, 2003 | 08:47 AM
Victim64's Avatar
Thanks. Is it actually a noise that the clutch will make though? Like something rattling around?? Thanks!
Old Jun 6, 2003 | 09:00 AM
mtrai760's Avatar
'Trynna' is not a word
Its not really a noise, but a feeling. When your letting out the clutch, it will 'chatter' kinda skip and not grab smoothly.
Old Jun 6, 2003 | 09:08 AM
Jeff92se's Avatar
I'm needing a caw
Imagine going around a bumpy turn in a 4-gen. Then imagine that feeling though the engine.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
ag90fox
Sep 9, 2015 12:22 PM
