Couple quick Q's about emblems and springs
real quick, 2 Q's
I shaved off my nissan burger on the trunk, and i read that it leaves the imprint of the old emblem, and i can see it barely, does this go away? i washed over it and waxed it but i can still kinda see it? any help would be great
last, if i were to buy lowering springs for my car with the stock 16s, could i buy some say 17s, and still use those same lowering springs? would the drop be the same? thanks
Yes the mark will come out with time and sunlight. It needs to fade to the shade of the rest of your paint.. give it a month and wax/claybar frequently.
You could buy up to a 19" wheel without worrying about rubbing even with lowering springs. What really matters is the width of the wheel (I know 9.5" will rub). Anyways a standard 17"x8" or 18"x8" wheel should not rub with any lowering springs, granted you pick the proper tire size.
-Cyrus
-Cyrus
-Cyrus
-Cyrus
Originally posted by 99MaximaSE-L
ok good, what about the SE-L emblems, are they the same way? has anyone ever taken those off? and did it look ok? thanks
-Cyrus
03-12-2020 12:06 AM
imported_Nismo_max
02-17-2016 03:39 AM
