Problem: Fuel Injector!
Old Jun 9, 2003 | 12:07 PM
Max96GLE's Avatar
Hi Everyone!
Someone told me my car's fuel injector could be the problem to my bad gas mileage. Now my question is, which type/brand of fuel injector work best for a 1996 Maxima with 111,500 miles? I know there's alot of brands of fuel injector oil, but I don't know which one works the best.
My other question. What is a PCV? How can I go about testing the PCV if it's bad or not?
P.s.: My car is going 14 miles per gallon of gas.
___________
1996 Maxima
Old Jun 9, 2003 | 12:59 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Problem: Fuel Injector!
Originally posted by Max96GLE
Hi Everyone!
___________
1996 Maxima
it could be the problem but i wouldnt just start replacing things espically injectors. are the plugs, fuel filter and air filter in good condition? i would start with those if they have not been replaced since they are typically the culprit and cost less. for the injectors, if you want to replace them-bosch will do fine. you should be able to pick them up at any auto store or nissan if you want to pay a little more. pvc-positive crankcase ventilation. its a little elbow piece on the bottom side near your throttle body. i would just replace it since its only about 6 bucks when you do the rest. i would also clean the throttle body while you have it off. if you need any direction, i would look at purchasing a haynes or chilton manual as they can walk you through many repairs of this kind.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
