HELP! car wont start
Old Jun 19, 2003 | 09:16 AM
dm7297's Avatar
help help my car wont start, it cranks but wont start, kinda like when you use a key with out the chip in it. only thing i can think of is its my alarm fuel cut off, b/c i had the fuse box open and forgot to close it so my hood didnt close all the way and i tried to start it, with the hood up alittle, is the hood tied into the alarm? also is there any way i could pull codes off a 5th gen with out going to a dealer, like the 4th gens?
any help or ideas would be great
Old Jun 19, 2003 | 09:41 AM
MaximaMoJo's Avatar
Yeah, this sounds like a fuel delivery problem. Can you here the fuel pump come on when you first turn the key to or past the ACC position? I know the alarm for the fourth gen is tied into the hood. If it is not the alarm, then it might be a bad fuel pump. As far as ECU codes that might be in the FAQ's in the 5th gen forums.
Old Jun 19, 2003 | 09:44 AM
dm7297's Avatar
thats a good point ill listen for the fuel put thing when i get home from work, its under the rear seat right?
Old Jun 19, 2003 | 11:37 AM
MaximaMoJo's Avatar
Yeah, you should be able to hear with the radio off inside the cabin of the car. It sounds like a soft click sound. You shouldn't have to take the seat out or anything.
Old Jun 19, 2003 | 02:31 PM
dm7297's Avatar
ok i can hear the fuel pump come on it clicks then makes a short buzzing noise but still no start, had the bat disconnected for like 6 hrs and still nothing, i just noticed my upd is leaking oil from the crank seal would that cause it not to start?
Old Jun 19, 2003 | 04:41 PM
dm7297's Avatar
my dads friend fixes cars he looked at it and said that the injectors are not getting pulse he seems to thinkg the crank shaft sensor is either shot or not working right so i donno
Old Jun 23, 2003 | 08:53 AM
MaximaMoJo's Avatar
Do you have a RVM underdrive pulley? If you do I would do some searching. First thing I would do would be to put the stock pulley back on and see what happens. It is probably your crank position sensor. Good Luck, let us know what it was.
Old Jun 23, 2003 | 02:39 PM
dm7297's Avatar
its not the pulley cuz it was working fine when it was first on, it is the crank shaft sensor cuz its at the shop now, it go ruined cuz oil was leaking on the sensor b/c the person who put it on didnt replace the oil seal that i game him grrrrr
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
