fuel filter
Old Jun 20, 2003 | 12:06 AM
asf4life's Avatar
fuel filter
im having a problem changin my fuel filter, i was able to get a screw drvie down there to loosen up the clamps, and slide them out but the hose was on the filter so tight i couldnt pull it off, even after i depressurized the fuel pressure, i was able to change my fuel filter which is the same principle, but there was more room, in which i was able to twist the hose off, but i can't do it on this, im pretty sure the filter was never changed and i onyl got 70k doing my 60k service, so wat do you guys recommned i do to take the hose off, i wanted to sue a plier but dotn want to rip it off, if anyhitng ill cut the hose and just go buy another one at the dealer
Old Jun 20, 2003 | 05:30 AM
njmaxseltd's Avatar
Remove your intake from the throttle body to the air box. That will give you more room to work. Use a pair of pliers, grab the hose and twist that sucker off.
Old Jun 20, 2003 | 08:31 AM
patel_anu's Avatar
what i did to make it a little easier for me was take a flat head screw driver and wedge it in between the hose and filter and twist it so it slowly goes up, hope that helps
Old Jun 20, 2003 | 08:36 AM
max7's Avatar
Yeah that's what I do. I also remove the intake and than it's easy to get at.
Old Jun 20, 2003 | 09:03 AM
HSVMaxima's Avatar
Re: fuel filter
Use a hair dryer to warm up the hoses and you'll be able to pull it off.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
