Clutch Cable????????????
Please HELP, Clutch Problems
My clutch is always enguaged,I have to have the clutch pushed in for the car to start and when I do this the car will start to go.
Please ask any questions you need to inorder to help me.
Thanks alot
Thanks alot
Originally posted by acidspit86
no clutch cable, they are hydralic. try bleeding clutch master and slave cylinder
Basically your cluch is not disengaging from the flywheel because of a problem with the hydraulic system. Could be a bad master or slave cyl.
Umm...Have you tried bleeding the clutch? That should be the first thing you do. If this doesn't help then at least you'll know something needs to be replaced. Then post back here with your results.
pktaske
Sep 4, 2015 08:40 AM
