Mounting body kit question...>
Old Jul 9, 2003 | 07:23 PM
nupe500's Avatar
Jedi Knight
My kit is going to be ready by next wednesday for pick up...I'll prolly pick it up on Friday and install on saturday. Where can I find the 3M double sided tape to buy...and should I also use rivets...? I've seen that mentioned before...any help would be appreciated.
Old Jul 9, 2003 | 08:48 PM
HitManSE's Avatar
Use the rivets, I dont know if its necessary to drill the holes be4 its painted but I pre-drilled mine just to make sure not to crack up the paint but I might just be exaggerating DO NOT use the double sided tape stillen gave you, go to home depot and get youself some strong double sided tape that will hold, stillens will let go.
Old Jul 9, 2003 | 09:35 PM
Nismo's Avatar
for the sides I used the 3m tape and also very small sheet metal screws on the ledge. I used no rivets at all for the front, just the tape and a bolt in each fender. very strong its not gonna go anywhere
Old Jul 9, 2003 | 09:46 PM
EteRnity059's Avatar
Boosted?....
For my stillen front lip, I just used the two screws in the fender well and some double sided tape. For my ionic sides, I put on screw on each side of the fender well and one on the bottom. For my ionic rear, I used 2.5 " metal screws all around my bumper. I previously used 1.5" screws and they just came loose to easily. It's not hard to screw in the back just have a friend hold up the rear piece as you drill.
Old Jul 9, 2003 | 10:03 PM
KLoWnPR109's Avatar
Front lip, I put three SCREWS in each fender well, and three by the foglights, and three on the underside. Used double sided tape but it wasn't necessary on the front for me.
Might be a little overkill, but its not going anywhere.
Old Jul 10, 2003 | 02:37 PM
ZeRo MaX's Avatar
do you actually just use a drill.. and drill the SOB in... cuz i still gotta drill my back pieces on... 2.5 inch metal screws right? did u do anything else.. or jus drill it in...
Old Jul 10, 2003 | 06:39 PM
BIGMAX's Avatar
I used screws to hold my kit on.
Big MISTAKE!
I no longer have a front lip it got stolen!
Screws are too easy to pop out or unscrew.
I'd have somebody who knows how to rivet put them on.
Old Jul 10, 2003 | 07:48 PM
carnal_c30's Avatar
Former Sponsor
I've had mine on for like 2 years like that and have had no problems
Old Jul 10, 2003 | 08:32 PM
BIGMAX's Avatar
I had mine on for two years also like that, and it was ripped off a month ago.
I doesn't matter how many trouble free years you've had, all it takes is one a$$hole.
Old Jul 11, 2003 | 08:11 AM
Boosted?....
I used 2.5 inch screws so there would be a lot of thread left to hold the rear onto the bumper. As to how I drilled. I used a dremel with a drill bit. I drilled the holes into my rear first, then had my sister hold the rear up to the bumper. I drilled through the predrilled holes on the rear piece and went lined it up with the bumper. Be careful though, you might have to drill at an angle. After all the holes were drilled, i screwed them in by hand.
Old Jul 11, 2003 | 09:05 AM
nupe500's Avatar
Jedi Knight
I'm planning to use a combo of all mentioned ways ...from the tape to rivets to screws...in the city of brotherly luv..."They love to take a Brothers stuff"
Old Jul 11, 2003 | 03:52 PM
nubiannupe's Avatar
OG Maxima.org Member
For sure!!!
Oh, and EteRnity059... can I use your sister to hold up MY rear?
(just so you know, I'm just jokin')
Old Jul 11, 2003 | 04:33 PM
ZeRo MaX's Avatar
Originally posted by nubiannupe
For sure!!!
good one good one...
i'm gonna be screwin' my body kit on soon here.. i have the front on.. but not the rear....
Old Jul 11, 2003 | 09:27 PM
LatinMax's Avatar
I must have done it all wrong. I had mine all molded on to the rest of the car.
Old Jul 11, 2003 | 11:00 PM
95emeraldgxe's Avatar
double tape can be purchased at autozone, i would double tape and then use screws
Old Jul 12, 2003 | 12:52 AM
Nismo's Avatar
u gotta have something else holding it together besides some filler dont ya?
Old Jul 12, 2003 | 09:37 AM
LatinMax's Avatar
I had all the factory brackets molded into the after market bumpers then used the factory hardware to mount it all back into place. It is installed nthe same way the factory bumpers where installed.
I was kinda joking about the previous post.
For the Stillen type kits I would not use Home Depot or Auto Zone 2 face tape. I would goto a body shop supplier and by there 3-m stuff that is made for cars. You know like the stuff they use to put the fat color coded rubber pieces that run downd the side of our cars, to protect the doors.
Old Jul 12, 2003 | 10:07 PM
Boosted?....
For sure!!!
SURE WHY HECK NOT HEHE
Old Jul 20, 2003 | 06:34 PM
ZeRo MaX's Avatar
did u get the body kit on yet?
Old Jul 20, 2003 | 08:10 PM
nupe500's Avatar
Jedi Knight
no...body guy taking his sweet time...should and I say "should" pick it up on Tuesday...we'll see...pics will come when I do...so don't worry
Old Jul 20, 2003 | 08:32 PM
licrisisfe's Avatar
One thing for sure...do NOT use the Stillen double sided tape...it's junk. I used it on the front lip along with a couple of rivets at each side fender well. The bad tape let the lip sag. Later, I went back and pulled it up tight and added a few small rivets to the front of the lip and used touch up paint to cover the rivet heads. Click my links to see the results.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
