Engine Swap, Day 1
Engine Swap, Day 1
Well, 1.5 kinda.
Thursday night I took the car to my Dad's where I'd be doing the swap. Took the hood off, splash guards off, front suspension out and drained all the fluids.
This morning at 9AM I got to work. Today I got the following accomplished:
- Intake path out
- Radiator/Water hoses out
- Axles out
- Starter, shifter control rod, Clutch release cylinder un-hooked
- Wiring harness unhooked
- Fuel lines unhooked
- AC Compressor disconnected (from block)
- PS Pump disconnected (from block)
Not quite as far as I liked. I wanted to get the tranny out today. However, I relized I couldn't do so without removing the cross member, and I didn't like the idea of leaving the engine supported by a jack or hoist for the night. So, I'm going to take the tranny then engine out tomorrow.
The Passenger side axle was a major pain in the ***! The Hayned manual stated to remove the 3 bolts around the bearing in the support bracked. Nowhere in the insrtructions did they mention un-bolting the bracket from the block. Well, after about and hour and a half with it, I unbolted the bracked from the block and the thing came right out. I pulled so hard that I seperated the inner CV, so I'm going to have to take that boot off and re-assemble it. Oh well. I am going to re-boot the outer CV's, but I guess I'll do the inners while I'm at it.
After that I got a flat tire in my Dad's Ford Ranger, which I'm driving while this is being done. I had to waste almost three hours dealing with that, so that slowed me down a lot!
Pictures: http://www.ericj.org/maxima/img/engine_swap/
[EDIT]
Pictures from day 1's work start with a '1', day 2's work with a '2', and so on.
[/EDIT]
Tomorrow I have to seperate the engine and tranny and remove both. Shouldn't have a problem getting that done, and I'll be right on schedule (engine out by the end of the weekend).
So far, about 7 hours into it.
- Intake path out
- Axles out
[EDIT]
[/EDIT]
You didn't have to remove the bracket. Your CV axle probably rusted to the bracket. All you had to do was insert a metal wedge in between the bracket and the axle and knock it loose. But, you got it out anyways, so it doesn't matter lol.
Good luck on this. Keep us posted....
I did have the same problem when I was converting my car to 5-speed. It would NOT come off for the life of it. But after hitting it with a metal wedge thingie and a huge 5-pound metal hammer, came off like a champ lol. But you got it off, so who cares lol. I hope the rest goes easy.
BTW, how many miles did you have on the old engine and how many on the new one?
sounds like things are moving along. a couple comments though. first of all, you got the PS pump unhooked, congrats, the hardest part of your motor swap is over!! secondly, why would you have to remove the crossmember for the tranny? I have removed my transmission maybe 10+ times, and motor a few times, and do not think I have ever taken off that engine crossmember..
good luck on the rest of it!
Just FYI you dont have to remove the crossmember to yank the tranny out, you just need to have the right tools I just did a clutch on a 4th gen less then a week ago so yeah im pretty sure. As for the pass side axle, it is somewhat of a PITA. I didnt actually remove it, what I did was when the tranny was loose, I just pulled the tranny off the block and used a 4ft long screw driver/pry bar to pop the axle loose and just pulled the tranny off.
The only PITA about the axle is those bolts are so damn tight. Once the tranny is out, your obvioulsy gonna have more room in there hell you do something many times and you get used to it and takes less time each time around
You've captured my curiosity... what exactly are you doin?
Well, the cross member is blocking access to one of the bolts on the tranny support rod. For the life of me I can't figure how to get that bolt off with the cross member on there.
Its coming off anyways, so it really doesn't matter.
Craig - Blew my engine with a MEVI screw. Didn't consider rebuilding an engine. Wanted a simple(r) swap.
Re: Engine Swap, Day 1
Originally posted by ejj
Well, 1.5 kinda.
- Intake path out
- Axles out
Well, 1.5 kinda.
- Intake path out
- Axles out
you need to work faster.. if not it is gonna take you forever...
I knew about you losing the screws into the engine from the MEVI but I thought you were gonna build it (or have some1 build the motor) and you do the swap.
Either way good luck.
Originally posted by Craig Mack
Ejj, why are you swapping engines? And did you ever consider using the 3.5VQ crank to up displacement?
Re: Re: Engine Swap, Day 1
Originally posted by HitManSE
It does block access to one of the bolt yes, but like I said use the right tool and after you get it off you will fell like but your right, its coming off anyway so it doesnt matter. Have fun doing the swap, the only HARD part I consider there is with a job like this is keeping track of were all the studs,bost,nuts,screws all go. Just take your time, but the 7hrs of your you did should have taken you 4hrs at the most but im guessing you just took your time. Nissan has setup almost everything in a simple to access location in the maxima. Except the exhaust manifolds and the rack and pinion most everything is simple. I would hate to do the rack on a max, its looks to be such a PITA.
I'm using zip-lock bags...lots of them. Each 'section' gets its own bag (ie 1 per mount, 1 for tranny bolts, etc).
Day 2 update here:
http://forums.maxima.org/showthread....hreadid=232568
Re: Re: Re: Engine Swap, Day 1
Day 2 update here:
Day 2 update here:
Re: Re: Re: Re: Engine Swap, Day 1
Originally posted by axim
I recently blew my motor and I am going to swap it out. Ejj, have you ever replaced a motor before or are you just following the Hayned manual? Also I saw someone mention something about using a 3.5 crank? Can a 3.5 fit with no issue in a 99?
I'm using the haynes manual and FSM for reference now and then, but primarly just figuring it out as I go.
The 3.5L crank is not nearly that simple...search for posts about it by MardiGrasMax. Its quite a project.
Rebuilding the motor is and saying its quite a project is a bit of an understatment. There is 29.9hrs in my labor book that is required to take apart the put the VQ30 block back together. I think the Crank is at 17.X something alone. Around the engine most everything is setup simple, but in the engine its a PITA!
Ray229Harris
09-16-2015 08:16 PM
maxinout93
08-20-2015 02:17 AM
