O2 Simulators ?
Old Jul 13, 2003 | 03:14 PM
rich96max's Avatar
O2 Simulators ?
Are they worth picking up or should i just go with replacement O2 Sensors for the both front manifold O2 sensors?
Old Jul 13, 2003 | 04:15 PM
BigDogJonx's Avatar
You cant use these on the two front O2s. Those are true O2 sensors. There is one in each manifold to measure rich/lean of each bank. Then on the Fed spec cars they got one O2 behind the Catalytic Convertor to see if the Cat is working/there. On the Cali Spec cars, there are two of those, Both of them looking at the precat's.
Only put the O2 simulator on the cat-sensing O2 sensor(s). Are they worth it? Well only way I see it being worth it is if you got a boosted application and want to get rid of all the catalytic convertors to gain the much needed 10whp from them. Then it is worth it. Im doing this on mine to remove the two rear cat-sensing O2s in mine. The simulator will keep the SES or Check Engine light from coming on cause it fools the ECU in thinking the Cat is still there.
Dixit
Old Jul 13, 2003 | 05:19 PM
rich96max's Avatar
thanks man i guess i will be picking some new ones up soon, the best price so far that i have found one them is from http://www.buyoxygensensors.com/ OEM's are $63 each and the Universal ones are $42 each. Is that a good price on those?
Old Jul 13, 2003 | 05:24 PM
BigDogJonx's Avatar
I guess that price is good. Try calling DaveB at South Point and see what he gots them for.
Dixit
MaximaDrvr
Aug 19, 2015 08:20 PM
1992maximase30
Aug 5, 2015 09:27 PM
BlackBIRDVQ
53
Jun 4, 2007 12:44 PM
NmexMAX
Jan 12, 2005 09:05 PM
