4th gen with dif. way to open trunk.
Old Jul 13, 2003 | 09:47 PM
Titleistprov21's Avatar
I saw it today at the Franken Car BBQ. It was AWESOME! Some people told me you could buy the kits on ebay for $5. Does anyone know what im talking about? The trunk lid swings up and over, but stays parallel to the car. Could someone please let me know where i can buy this kit? Thanks
-Pat
Old Jul 13, 2003 | 09:50 PM
MaximaZero's Avatar
Needs non-Maxima Friends
I think people refer it to the "flip-flop" trunk mod or something like that. And also, you should be able to get the parts from Home Depot. All you need are the instructions.
Old Jul 14, 2003 | 03:37 AM
Bags's Avatar
VG Ridah's Biatch Hoe
if you do it.. have it welded
Old Jul 14, 2003 | 02:58 PM
R5a7B's Avatar
http://www.vqpower.com/v2/modules.ph...showpage&pid=7
Rich
Old Jul 16, 2003 | 11:59 AM
Another question, will this fit a 5th gen?
Old Jul 16, 2003 | 02:43 PM
TitleistPrto's Avatar
Any car, check the sig.
Old Jul 16, 2003 | 11:52 PM
araffio's Avatar
That was me
Cost me $10 for 2 strap-hinges and L-brackets at Home Depot. I don't feel like doing a write-up. It's not hard at all to figure out and design yourself. DO NOT buy the eBay kits, they are made of weak metal and will bend easily.
BTW- I didn't weld mine and it's 100% strong and straight after 2 months
Old Jul 17, 2003 | 06:10 AM
97GLES's Avatar
Originally posted by araffio
That was me
Tony did you send me the pics?
Old Jul 17, 2003 | 07:58 AM
R5a7B's Avatar
That is the write up
Old Jul 17, 2003 | 01:53 PM
95emeraldgxe's Avatar
flip flop trunk..... dont open it when its raining
Old Jul 17, 2003 | 02:04 PM
araffio's Avatar
Unless I remove the 4 main bolts that hold the trunk lid to the support arms, my trunk functions completely normal. You'd never even know I had the flip-flop mod...
Old Jul 17, 2003 | 02:45 PM
Chitwista's Avatar
I was just curious if any one with a big sound system has done this modification? Being that the only thing holding the top of the trunk to the OEM hinges is that little latch, unless it is really tight (which in the write up it isn't), it is going to cause all kinds of rattles.. Just a thought..
Old Jul 18, 2003 | 10:08 PM
nubiannupe's Avatar
OG Maxima.org Member
We'll find out in a couple of days...
Old Jul 19, 2003 | 07:23 AM
araffio's Avatar
Here's a pic I just took. It's the clearest I could get it, my camera is not good for close up shots for some reason.
As you can see, I used a strap hinge cut to length, which I then fastened to both the trunk lid and support arm, then bent the end over the support arm. I then used an L-bracket to support the hinge even more. I had to grind down the bolt heads on the hinge to give it enough clearance to flip-flop.
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Vequity
Sep 10, 2015 05:26 AM
Lowered_a33
Sep 1, 2015 07:49 PM
